1
- #1
Enginerdad
- May 18, 2012
- 66
I'm in the process of designing a UHPC beam end repair which requires welding shear studs to the existing beam web and then encasing the beam end in UHPC to create a new load path for the compression in the deteriorated web. If you're unfamiliar, here's a cool little video explaining the process.
In my situation, the existing beam has a double bearing stiffener which are 6" on-center and 1/2" thick each (see image below). What I want to do is put a column of 3/4" shear studs in between the stiffeners as shown by the red circles, but I don't know how to be sure the 5-1/2" clear space between bearing stiffeners is enough for the installation of studs. Does anybody have a reference on minimum installation clearance for studs?
