Does anyone have experience with reducing compressor blade to case clearances using abraidable coatings, ie... Aluminum, Honeycomb...? I am looking for the effects of different clearances on compressor performance or possible surge due to excessive turbulence caused a negative clearance. I am actually trying to acheive the optimal clerance but am experimenting with extremes on both ends of the spectrum. Any help?
