kaspor
- Aug 12, 2021
- 33
Hello
I have two 90x90 square hollow section columns.
I need to cleat a 300x90 PFC beam between the columns, however I need the flanges of the PFC to be flush with the column face.
This means it's impossible for me to cleat the PFC to the centre of the column. I need to offset the cleat connection onto the column by 74mm (PFC web is 16mm thick). This means the PFC will be cleated onto the column, 16mm in from the edge of column.
The PFC is holding the upper storey of a residential home.
Is this acceptable? I cannot find any typical connection details for this in any Australian Standard. Does anyone have any material with these types of standard connections?
