multicaduser
Industrial
Start with a part containing only sketches, outline of a plate is one sketch, another sketch only has points for hole centers, all controlled by expressions. Create "Interface Objects" of the sketches in this file and use "Wave Interface Linker" to add the sketches to other files creating plates with holes. Then create an assembly which contains the sketch file and the plate files.
Now when the assembly is cloned everything updates except the sketches linked through "Wave Interface Linker", they still reference the original sketch file.
Is this "working as designed" or a bug?
tia
NX 1980 Windows 10
tia
NX 1980 Windows 10
