JHanson717
Industrial
In a closed loop cooling tower system, is there a "best practices" as far as if the pump should pump from the tower return to the heat exchangers, or pump to the tower and the tower returns through the heat exchangers?
It seems like it shouldn't matter, all components are rated for pressures well in excess of the discharge pressure, or is there another reason?
