Drusilla,
Please do not take this the wrong way. We want to help.
Step 1 to solving any problem is actually understanding the problem. Right now I don't, and it sounds like you don't either.
So, like you said, small steps. Lets see if we can help formulate the problem:
You have a machine that performs some sort of test on a fluid stream. The machine most likely has a place for the fluid under test to go in, and a place for the fluid under test to exit. Right?
What other connections are on the machine?
Does the instruction manual for the machine give any guidence about what conditions (flow rate, pressure, temperaure) must exist for the fluid under test at the entrance to the machine?
If there are other connections to the machine, does the instruction manual give any guidence to what, and at what conditions the things that connect to the machine must be held to?
Your second post mentions two devices. The first device is a machine that performs some sort of test on a fluid stream. What is the second device?
Your second post implies that something goes down the drain currently. Is the thing that is going down the drain the fluid under test or some other fluid? Does it come out of the machine that performs some sort of test? If so, where does it come from before it enters the machine?
I'm sorry that I can't come up with any other questions from the information provided so far.
