Closing dialog application
Feddozz
GB
Hello everybody,
I'm developing a small dialog application. it's got the cancel button, when you press it it closes the application, and that's fine.
I want the application to be closed when I type in Alt+F4 or I click on the red cross button, the button you usually use to close every window.
My code at the moment appears like this:
Code:
SUBROUTINE WinATDSub( dlg, id, callbacktype )
!DEC$ ATTRIBUTES DEFAULT :: WinATDSub
  use user32
  use dflogm
  implicit none
  include 'resource.fd'
  type (dialog) dlg
  integer id, callbacktype
  if (callbacktype == dlg_destroy) then
    call PostQuitMessage(0)
  endif
  END SUBROUTINE WinATDSub
What should I add to make it appen?
Feddozz:
The Dialog function in Intel 9.0 or higher and CVF 6.6c permits the dialog to be introduced as mode or modeless dialogs. There is a starting procedure dlgint(Idd_Dialog_Name,dlg). To close the dialog the procedure is dlgUnint(dlg).
There may be other commands from a dialog system similar to the above. I have found Intel to be an excellent source for fortran-windows interface. You can also search for absoft, lahey and other fortran-windows compilers.
I found the Intel Forum very good.
What I found:
the DFLOGM code checks if a button with IDCANCEL exists, and, not having found it, does nothing.
Solution: add a button with "Close" or "Cancel" caption and assign identifier IDCANCEL to it (or change the properties of "Apply" button if you don't need it). The button may even be hidden (Visible=false) if you don't want it visible.'
Thank you all for your help.
