Coagulant Dose 1
Lan123
155
Good day all,
I am having trouble in trying to calculate the Aluminum (Al) wt. in the liquid alum that is dose at one of our treatment plants. The alum (Al2(SO4)3.18H2O ((48%) - Molecular wt. 666.132) daily dosing wt is 101.63 kg/d. If so would the Al (MW =27) daily dosing wt. be = 101.63*2*(27/666)= 8 kg/d? (factor of 2 is because 2 Moles of Al in Alum).
Thanks in advance.
That is correct. If you review the link below, it should be helpful:
Al2O3 is the active ingredient and that is what you are paying for when you buy aluminum sulfate. 8.5% Al2O3 is sold because that concentration has the highest freezing temperature which is practical consideration for shipping and handling.
Percent Al2O3 is a common method of quoting the strength of aluminium-based coagulants on a w/w basis. Another method of referring to concentration is to state the aluminium content, which is roughly half the Al2O3 content. For example, liquid alum of 7.5% w/w Al2O3, which is the same as 4.0% w/w aluminium (Al).
The term percent weight/weight or % w/w is similar to the previous term and is the number of kilograms of active chemical per 100 kilograms of liquid chemical. For example, liquid alum at 7.5% w/w Al2O3 has 7.5 kg of Al2O3 in solution for every 100 kg of liquid chemical delivered.
Unfortunately, General Chemical has changed hands and taken down some of the links.
Wow bmir. another great explanation by you. Although I have seen 7.5 W/W Al2O3 never thought about 7.5 kg in 100 kg of chemical!!.
