lukin1977
- Jan 19, 2009
- 397
I am designing a tank that has to be filled with sulfuric acid (7% in water)
The tank will be made with A36 steel sheet 1/8”
Then I need to coat the inner surface of the tank.
Can you recommend a material for the inner coating? I am looking for something that can be applied with a brush. Maybe several layers of it
The tank is 0,40x0,40x5 m – open top
