Rwelch9
- Apr 22, 2020
- 116
Regarding my attached sketch,
I have made Datum A ( the mid plane between the two end faces)
The two pocket feature that determine Datum feature B , has 2X position tolerance to |A| this should establish a pair of tolerance zones at 0 basic location relative to each other and 90deg basic orientation to A.
My question is when i checking the pockets axis falls within the oriented and located tolerance zone that has been created .
Is it just the length of the pocket that has to fall within ?
or do you have extend pocket axis to when it meets ( A )
See the sketch for my interpretation. Top one is just the length of the cylinder bottom is the axis error projected to ( A )
Ross
