Code case about WB36 material 3
Raaden
89
Hi everybody!
I have heard rumors that there is an ASME case that allows the EN material WB36/15NiCuMoNb-5-6-4 (1.6368) to be used in an ASME installation, can anyone confirm this?
If this really is the case, what max allowable stress values should be used in an ASME VIII, div 1 application. (I guess that ASME doesn't allow you to just use the stress values from the appropriate EN-standard)
Pontus
See Code Case 2353. It applies to WB36 pipes and tubes only and only mentions Code ASME 1.
Thanks ijzer!
Unfortunately my company is very cheap :) so we haven't bought the code cases from ASME i.e. I can't look it up.
Does the case say anything about stress values?
They recognize two classes , with slightly different Normalized and Tempered conditions.
Class 1 Tensile at RT 90ksi Yield 64 ksi
class 2 Tensile at RT 95.5 ksi Yield 66.5 ksi
Allow. Stresses at temperature:(ksi)
Temp.Deg. F Class 1 Class 2
100 25.7 27.3
200 25.7 27.3
300 up to 700 25.1 26.6
Thanks again ijzer!
You've been a great help.
I need some help!!!
I'm a beginner
i must perform the strenght calculation about fittings for
power station
Usually i do that By ASME B31.1
but this material (WB36)is not listed an that rules
and i cannot find the allowable stesscan be apply
sorry for my english
Your question is a little confusing. However, what I believe you are asking is can the ASME 2353 code case for WB36 material be used for B31.1 application?
The answer is no from an administrative standpoint. You would need to have a code case submitted to the B31.1 technical committee to allow use of this material. The code case 2353 only applies to ASME Section I application.
If you are at a location where B31.1 is not mandated by your Jurisdiction, you could use the allowable stress information in the code case and apply it to the formulas in B31.1 for WB36 material.
Thank you for your help
I only want to advise you that our customer give to us
a table with the allowable stress to take in to account
I don't know why but tha values are higer than that listed in the Code case 2353:
from 20°C to 420°c = 203 Mpa
430° = 200 "
440° = 182 "
450° = 163 "
460° = 140 "
470° = 117 "
Thank you
You should find out the source of the allowable stress data from your customer. Explain to your customer that unless the higher allowable stress values come from a reputable source or other standard, you will use the ASME Code case data.
"My" client now ask to me to perform (for another project)TRD calculation.
My Boss suggest me to take allowable stress for WB36
considering 2/3 Of Rp0.2 at temperature.
For P91 take it from Table A1 B31.1: i'm not agree because
with this value the min Wth. result bigger than requied.
I also must perform some calculation for tee pieces in P92
(With B31.1)can i use the code case 2179 for the allow. stress ??
Thank you
What is your pipe specification for P91? If it is SA 335 Grade P91, I would use the allowable stress value in Table A1 of B31.1.
If your client is installing the tee pieces as a repair to an existing piping system, Code case 2179 could be used for allowable stress values for P92 material. However, if this is a new high energy pipe installation and you are bound by contract to meet B31.1 code requirements, this material cannot be used.
