Our chemical plant has a plunger type valve on the drain of a pressure vessel. After repeated failures due to corrosion, they took a commercial valve and under the direction of an experience ME modified it by creating a new, sturdier valve body made from a different alloy and thicker pipe on the discharge side. It has worked well. My question is: How does that affect the legality of using that valve and are there any methods to have the valve tested and stamped to approve it for service, or is that even possible?
Thank you.
Thank you.
