Hossein Mohammadi H
I am simulating the separation of two different parts which are connected with a thin layer of cohesive elements in a 2D explicit problem. The simulation is conducted successfully without error. But the final results shown in the visualization module seems very weird (see the attached photo-left). I also simulated a similar problem via a static solver and my results do not show this weird distortion anymore (see the attached photo-right). Can anyone help to figure out the problem? Thanks in advance.
Additional information about interactions: in both cases, I used "tie" to connect the cohesive layer to right and left side parts. The interaction between the rigid body that moves downward and right/left parts is a hard contact with penalty friction.
