Cohesive elements do not converge when combined with ductile damage
WillingToLearn
Student
Nov 13, 2021
13
I have a model consisting of three components: Fibre (Isotropic), Interface (Cohesive Elements) and Matrix (Ductile Damage).
If I run the model without the ductile damage, it works fine -> Interface fails
If I run the model without the interface, it works fine (second picture) -> Matrix fails
But when I run both together, the interface starts failing and failure is also initiated in the matrix but then it does not converge: "Time increment required is less than the minimum specified".
I suspect that has something to do with the fact, that the matrix material starts failing at the cohesive interface.
At the point of non convergence, the dissipation energy spikes:
Settings:
One part with different sections assigned to it
Units: Length[µm], Time [ms], Stress [GPa]
Periodic Boundary conditions
Solver: Unsymmetric (as recommended in the manual)
Minimum time step: E-25ms
Maximum time step: 10ms
NLGeom: On
Specific dissipated energy fraction: 0.0002
Max ratio of stabilization to strain energy: 0.05
Maximum degradation (matrix&interface): 0.99
I've spend many hours trying to find a solution but was not successful. I also asked in the simulia forum, but was not able to solve the issue. Do any of you have a suggestion for me?
Kind regards
Mike
Sometimes it helps when you adjust the solver controls, especially in the case of highly nonlinear damage and fracture mechanics problems. Do you use static step here ?
Thank you for answering so quickly. The pictures above show a static step, but I also tried implicit dynamic and it did not change anything.
Which solver controls would you recommend to change? I have basically no experience with this.
You can try this:
- turn on discontinuous analysis
- increase the max number of attempts to 20
This is recommended for XFEM analyses but there’s a chance that it will help here as well.
Apart from that, enable viscous regularization in element type settings.
