I have a client that wants to place a cold joint in a foundation wall. It's a residential structure and the foundation is being constructed with ICF's. The builder is worried about blow-out at the bottom of the forms as some of the walls are 11' tall. His concern seems legitimate, though I need to check the ICF manufacture's spec. sheets to see if this is really a concern or not. The question still remains though about having a cold joint in the foundation. I've never heard of this before in a residential structure and can not find a suitable reference in the ACI pertaining to cold joints.
The wall is reinforced for the lateral soil load with the rebar in the proverbial tension zone. In theory is seems like it should work as zero tension capacity is assumed for concrete anyway and the joint in the compression zone would be in compression, so that shouldn't matter either. I have some concerns about moisture infiltration, but I would really like to be able to cite a reference one way or another on whether or not a cold joint is allowed.
Can anyone help?
Can anyone help?
