We are receiving portions of an aluminum 5456-H116 plate (4.00" wide x 0.250" that has been pressed to form a Vee shape of 110 degrees. On the external side, where the bending is we are seeing small longitudinal cracks. the engineer from the company providing the plating says this is normal surface irregularities. I, on the other hand, am concerned of possible stress corrosion cracking in the future. However, I have not been able to find "industry standard" for accept/reject criteria of any cracking as part of the fabrication process. Anyone have ideas on where to look?
