I'd like some advice on performing cold stretching for a vessel intended for cryogenic storage (ASME VIII-1 Mand App 44). I will list some items for discussion.
1- Pc (cold stretching pressure) is said to be between 1.5P and 1.6P(inclusive). Do I need to keep this value constant during the process or any value within this range will do? During the stretching volume will increase, so I'd need to be controlling pressure, If value is to be kept constant it becomes a bit harder to control.
2- The cold stretching pressure shall be maintained until strain rate drops to below 0.1%/hr. This strain rate is calculated by repeated or continuous measurement of the circumference. Are there any recommended good practices / equipment to measure this circumference with minor deviations?
Thank you for your inputs.
