Does anyone have a feel for (or ideally some reference to) how far UPSTREAM cooling will take place in the pipe wall at a valve in gas service with a high dP.
In other words, a hydrocarbon gas at ~140 bar is depressured to flare (atmospheric + nominal back-pressure) via a globe valve. Valve and downstream pipework fabricated from Low Temp St.St. Upstream pipework is carbon steel whose minimum design temperature is greater than the expected gas temperature downstream. Should we specify a length of LTSS upstream of the valve also to account for conductive heat loss?
Will
Will
