I have to change the colors of hundreds of parts (using 20+ different colors) and I do not know how to make this journal work.
Here is the journal that I recorded, all I need to be edited is to select all solid bodies in part and to apply color with number form NX color scheme, like color 11 for example for "Light Yellow Spring" so that I can manually copy/past journal and edit it to use it for 20+ colors that I need.
THANK YOU!
_____________________________
Enjoy your work and have fun!
THANK YOU!
Code:
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
' Menu: Edit->Selection->Select All
' Refer to the sample NXOpen application, Selection for "Select All" alternatives.
' Menu: Edit->Object Display...
Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Start")
theSession.SetUndoMarkName(markId1, "Object Color Dialog")
' Dialog Begin Object Color
Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Object Color")
theSession.DeleteUndoMark(markId2, Nothing)
Dim markId3 As NXOpen.Session.UndoMarkId = Nothing
markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Object Color")
theSession.DeleteUndoMark(markId3, Nothing)
theSession.SetUndoMarkName(markId1, "Object Color")
theSession.DeleteUndoMark(markId1, Nothing)
Dim markId4 As NXOpen.Session.UndoMarkId = Nothing
markId4 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Edit Object Display")
Dim displayModification1 As NXOpen.DisplayModification = Nothing
displayModification1 = theSession.DisplayManager.NewDisplayModification()
displayModification1.ApplyToAllFaces = True
displayModification1.ApplyToOwningParts = False
Dim objects1(0) As NXOpen.DisplayableObject
Dim body1 As NXOpen.Body = CType(workPart.Bodies.FindObject("REVOLVED(6)"), NXOpen.Body)
objects1(0) = body1
displayModification1.Apply(objects1)
Dim nErrs1 As Integer = Nothing
nErrs1 = theSession.UpdateManager.DoUpdate(markId4)
theSession.DeleteUndoMark(markId4, "Edit Object Display")
displayModification1.Dispose()
' Menu: File->Save
Dim partSaveStatus1 As NXOpen.PartSaveStatus = Nothing
partSaveStatus1 = workPart.Save(NXOpen.BasePart.SaveComponents.True, NXOpen.BasePart.CloseAfterSave.False)
partSaveStatus1.Dispose()
' Menu: Tools->Repeat Command->4 Stop Journal Recording
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
