color palette... 2
studiotreccani
IT
i have use the program in this thread thread561-388210 for a while ,
and it work flawless.
(it change the cdf on every single file of an assembly)
Now i have change the computer
and on a new one does not work.
Any tips please.
I actualy work with NX 12.0.2.9 MP4
NX 10.0.3.5 MP3
The "UGII_ROOT_DIR" variable was phased out around NX 11 or 12. Try changing the following lines:
Code:
string rootDir = Environment.GetEnvironmentVariable("UGII_ROOT_DIR");
string colorPalette = rootDir + "\\ugcolor.cdf";
to this:
Code:
string rootDir = Environment.GetEnvironmentVariable("UGII_BASE_DIR");
string colorPalette = rootDir + "\\UGII\\ugcolor.cdf";
www.nxjournaling.com
Nope the string that you ask me to change was already change
succesfully in somethink like that:
//string colorPalette = rootDir + "\\ugcolor.cdf";
string colorPalette = "D:\\personalizzazione_nx\\cliente.cdf";
Work in 2007 on the old computer
Not work in 2007 on the new computer
I actualy work with NX 2007
and soon NX 2406
Does this file exist in the same location on the new computer? If this is on a network drive, is it mapped the same on the old vs the new computer?
Do you get any error messages in the interface or the log file?
Yes the directory and the file exist (double ceck...)
and the log file...
&MACRO FILE_BOX -2,@@@C:\personalizzazioni_nx\Cambio_cdf_a_tutte_le_parti_sostituire_il_nome_cdf_dentro_CP.cs@@@C:\personalizzazioni_nx\*.CS@@@ 0 ! Journal Browse
!!!&MACRO EVENT VALUE_CHANGED -30 5707, 1, 0, 0, 0! (Application CB Nested)
!!!&MACRO ASK_ITEM 1 (1 STRN 5707) = "C:\personalizzazioni_nx\Cambio_cdf_a_tutte_le_parti_sostituire_il_nome_cdf_dentro_CP.cs" !
&MACRO EVENT ACTIVATE -30 5707, 6, 0, 0, 0! Run
&MACRO ASK_ITEM 8 (1 MTXT 5707) = 1
&MACRO LINE (1) ""
Successfully loaded dynamic module C:\Program Files\Siemens\NX2007\NXBIN\nxclrldr.dll
Loaded module c:\program files\siemens\nx2007\nxbin\nxclrldr.dll 7ffc95800000 11000 a82696de-429d7d7c-77a83696-964b5296-1=nxclrldr___165335080264 version = 2007.3201.0.0
Loaded module c:\windows\system32\virtdisk.dll 7ffca31f0000 16000 84b6ecd2-58606d50-3d889ac6-829d10a9-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\bcp47mrm.dll 7ffcb8b60000 32000 573a4a68-88b1da3c-3d951221-a0f9ed6b-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\mrmcorer.dll 7ffcbcc70000 116000 31aecb4-852e77d7-eb0e2226-4fae3b7f-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\sxs.dll 7ffcd07c0000 a3000 9928b06c-1d1f08b8-e20b263d-d7f05af4-1 version = 10.0.22621.2506
Loaded module c:\windows\system32\appresolver.dll 7ffcad880000 9f000 6f4450fd-98f951ac-2d5a634d-3c587986-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\iconcodecservice.dll 7ffcbe190000 9000 f92fc801-b1c1f112-33e2041b-744ffa37-1 version = 10.0.22621.1
Loaded module c:\program files\avast software\avast\ashshell.dll 7ffbb1d30000 3c0000 279a5e69-43924253-83005193-46d1e5cf-1 version = 24.4.9067.0
Loaded module c:\windows\system32\photometadatahandler.dll 7ffc8ad00000 7e000 d7a56cb7-334019a2-1c398553-ae8d3499-1 version = 10.0.22621.3672
Loaded module c:\program files (x86)\dropbox\client\dropboxext64.73.0.dll 7ffc94d40000 95000 19556901-f43d4646-92366bb5-f1d3dc1c-1=DropboxShellExt version = 1.0.73.0
Loaded module c:\windows\system32\mssprxy.dll 7ffc9a350000 26000 37862441-7db710f5-1d2edd7f-9c9dc8e2-1 version = 7.0.22621.3085
Loaded module c:\program files\microsoft onedrive\24.111.0602.0003\filesyncshell64.dll 7ffc8dd80000 1d4000 9dbab3d0-9c411986-8d3f3592-8ad586b1-1 version = 24.111.602.3
Loaded module c:\windows\system32\ehstorapi.dll 7ffc957d0000 24000 b073eee5-e63b7cc1-da28d362-b14fe266-1 version = 10.0.22621.1
Loaded module c:\windows\system32\ehstorshell.dll 7ffcad000000 37000 cf665bfe-a76da01a-d46cfd-771dc0b6-1 version = 10.0.22621.1
Loaded module c:\windows\system32\portabledeviceapi.dll 7ffc84740000 9e000 df8f95fb-57c4268e-21a9a410-2cf542d1-1 version = 10.0.22621.3527
Loaded module c:\windows\system32\wpdshext.dll 7ffbc6390000 a2000 d8b3a12c-7aa4e169-5da8c05b-97c0d094-1 version = 10.0.22621.3527
Loaded module c:\windows\system32\deviceassociation.dll 7ffccc220000 12000 2da98ffb-a5dcbca4-fe63ccc9-a1cdfc3a-1 version = 10.0.22621.2506
Loaded module c:\windows\system32\devdispitemprovider.dll 7ffc9c9e0000 21000 59450b0f-790a46f2-78811fe7-6cdf9ce2-1 version = 10.0.22621.2506
Loaded module c:\windows\system32\playtodevice.dll 7ffc56b30000 69000 905c43fc-cad47ee0-18e5dc90-71999fa-1 version = 10.0.22621.1
Loaded module c:\windows\system32\dlnashext.dll 7ffcb8a00000 56000 8ec39275-f102987f-a8befdf1-1be4e44e-1 version = 10.0.22621.3527
Loaded module c:\windows\system32\wkscli.dll 7ffcc9150000 1a000 bcf4b93a-ecf38c15-108c7baa-40bf1649-1 version = 10.0.22621.3374
Loaded module c:\windows\system32\davclnt.dll 7ffc95d50000 1f000 2b784a59-a0113852-d7bdb589-f0ce036f-1 version = 10.0.22621.1
Loaded module c:\windows\system32\ntlanman.dll 7ffc923d0000 22000 8c027bf-23cf6ea6-d379d5b7-9155af87-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\drprov.dll 7ffcb55f0000 c000 ccd6fb13-83f98c83-75321832-ae6aa3c3-1 version = 10.0.22621.1
Loaded module c:\windows\system32\p9np.dll 7ffcb5070000 2b000 80c61e8f-4b35dbc3-f23cb73c-e7a130a5-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\cldapi.dll 7ffcb0460000 2d000 b9b1780e-64ead97d-4479e1ee-5d7d7065-1 version = 10.0.22621.2506
Loaded module c:\windows\system32\actxprxy.dll 7ffcafdf0000 7f000 730cf67b-efe4e012-959e3310-c55c1f6e-1 version = 10.0.22621.3085
Loaded module c:\windows\system32\networkexplorer.dll 7ffcbee30000 1a000 37a5eacb-443f316d-4876f39a-8e043ad3-1 version = 10.0.22621.3527
Loaded module c:\windows\system32\apphelp.dll 7ffccaf70000 97000 7bf6399e-fd6f529f-11009074-d7318138-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\cscapi.dll 7ffc9df50000 12000 6ba23e20-bcb31ad5-ab7509-f095ef3-1 version = 10.0.22621.1
Loaded module c:\windows\system32\ntshrui.dll 7ffc8dc30000 99000 4106279b-9cc48f17-4d7a6b40-b3ea975f-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\linkinfo.dll 7ffcc6b40000 d000 b53f165d-3b28e7d-d2dda0bc-b47331e0-1 version = 10.0.22621.1
Loaded module c:\windows\system32\windows.ui.immersive.dll 7ffcbe300000 175000 3e75e554-cd1f4a7-58130c0-a32f6622-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\windows.ui.dll 7ffcb9200000 175000 ead97c-41fd1c51-641f0400-fc4ee42f-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\windowsudk.shellcommon.dll 7ffc940c0000 554000 9499d13b-2cb56e8a-58455bee-b0cf08a5-1 version = 10.0.22621.3737
Loaded module c:\windows\system32\windows.staterepositorycore.dll 7ffcc8a50000 1a000 38dcbbe1-89edac62-bd71fbe8-d3c255f9-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\windows.system.launcher.dll 7ffcc4fd0000 135000 cbbb6f5c-15930d28-e4228594-a69af681-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\windows.storage.search.dll 7ffcb0650000 e5000 4bef12e5-475f8e8-ca0dc764-c5c0cb81-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\onecorecommonproxystub.dll 7ffcbc800000 ab000 bc56d800-be0a133b-1545fed8-b59c02aa-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\onecoreuapcommonproxystub.dll 7ffcb3700000 62b000 2af3220b-f6d80ecf-f5d602c2-88ca7ffc-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\structuredquery.dll 7ffcaccd0000 bb000 c88ff5ad-c0893e88-f1a99c2a-fbc4b546-1 version = 7.0.22621.3672
Loaded module c:\windows\system32\windows.staterepositoryclient.dll 7ffcc4f90000 3d000 8b8ba712-7342ceb6-967b65f2-21c68db3-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\windows.staterepositoryps.dll 7ffcbcf70000 eb000 64438ff5-94a4e3be-f27d92cf-d2224eb4-1 version = 10.0.22621.3374
Loaded module c:\windows\system32\msvcp110_win.dll 7ffccc930000 93000 2158bf9b-61d3de86-3e40000a-104e4af5-1 version = 10.0.22621.1
Loaded module c:\windows\system32\policymanager.dll 7ffcccd20000 a5000 228d1d35-175640f1-14313cca-84fd5e05-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\thumbcache.dll 7ffca3280000 6a000 2103a0e9-cc864e4d-6e198d7f-b0dbc60a-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\oleacc.dll 7ffcc87a0000 69000 2017edc6-f5ca59b7-bc7d7a43-2e5bc328-1 version = 7.2.22621.1
Loaded module c:\windows\system32\edputil.dll 7ffcb03e0000 28000 ee4a61de-f7b146cf-596c407d-70f9eb96-1 version = 10.0.22621.3527
Loaded module c:\windows\system32\duser.dll 7ffc5cc40000 99000 f7ce2bb3-77ca9b8c-a552dccc-2a145ad5-1 version = 10.0.22621.1
Loaded module c:\windows\system32\dui70.dll 7ffb9bfb0000 1bc000 3c6b111c-344772fe-6f21a009-53b940ef-1 version = 10.0.22621.3527
Loaded module c:\windows\system32\windows.fileexplorer.common.dll 7ffcb0580000 ae000 5f29a369-52ed277d-cc2c41f6-d95dd0ef-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\propsys.dll 7ffcccbd0000 101000 79b5dd1-3047e62-56bd9449-59bfc59d-1 version = 7.0.22621.3672
Loaded module c:\windows\system32\bcp47langs.dll 7ffcb9440000 60000 e6929d91-d0a6b59b-b43eecc7-9beb1dd9-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\globinputhost.dll 7ffcbfb60000 29000 38d58c8-1a595bca-ebeb8c33-fb53adcb-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\windows.globalization.dll 7ffca33c0000 1bb000 402a2ef4-a85fd39e-fda7a617-cae7a451-1 version = 10.0.22621.3672
Loaded module c:\windows\system32\msftedit.dll 7ffc92400000 36f000 4ac38229-f9e9c042-7c642cda-50a3a0f2-1 version = 10.0.22621.3672
Using C:\Program Files\Siemens\NX2007\nxbin\managed\ManagedLoader.dll to load managed DLL
Trying to load C:\Program Files\Siemens\NX2007\nxbin\managed\ManagedLoader.dll
ManagedLoader.Load: C:\Program Files\Siemens\NX2007\nxbin\managed\NXOpen.Utilities.dll Nome:ctx://Journal2cf53cc2
Nessun criterio di contesto.
AppBase: C:\Program Files\Siemens\NX2007\nxbin\managedLoaded assembly: NXOpen.Utilities, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\615f6e5b\0030262d_833cd901\NXOpen.Utilities.dll
Loaded assembly: System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 from C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
Loaded assembly: System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a from C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\NXOpen.Utilities.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\NXOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\NXOpen.UF.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\NXOpen.Guide.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\MiniSnap.dll as a reference item
Evaluating whether to add Snap library:
Cannot obtain authoring license from server
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\NXOpenUI.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\MFGViewMakerOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\DSEPlatformOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\DSEDesignWorkflowOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\AmMaterialsOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\BaseChecker.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\AnimationDesignerOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\RuleOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\MfgMlpOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\MPAOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\PressLineSimulationOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\TDPOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\DSEOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\MoldCoolingOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\CLDCommonOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\MfgAmOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\PIDOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\CLDKinOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\ToolDesignerOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\MfgModelOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\SafetyOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\JoinOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\AtsUnitTestDotNet.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\FalconOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\LineDesignerOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\AMEOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\CoatingsOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\StageModelOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\DMUOpen.dll as a reference item
Adding C:\Program Files\Siemens\NX2007\nxbin\managed\\MBDOpen.dll as a reference item
Loaded assembly: journal0, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\e91f09e0\2e4a6307_ccc6da01\journal0.dll
Loaded assembly: NXOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\ebe570ba\00e085f7_c7e0d901\NXOpen.dll
Loaded assembly: NXOpen.UF, Version=2007.4000.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\190e7a43\006de92f_69f4d801\NXOpen.UF.dll
TypeResolveHandler : NXOpen.Session
Loaded: NXOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: NXOpen.Guide, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\641f11c3\00c5e037_833cd901\NXOpen.Guide.dll
Loaded: NXOpen.Guide, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded: NXOpen.UF, Version=2007.4000.0.0, Culture=neutral, PublicKeyToken=null
Loaded: NXOpen.Utilities, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: NXOpenUI, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\79be795c\0098af36_833cd901\NXOpenUI.dll
Loaded: NXOpenUI, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: Snap, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\41498e66\00c89c23_833cd901\Snap.dll
Loaded: Snap, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: MiniSnap, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\b80637b2\00c5e037_833cd901\MiniSnap.dll
Loaded: MiniSnap, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: MFGViewMakerOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\2a5746bf\0022ff25_833cd901\MFGViewMakerOpen.dll
Loaded: MFGViewMakerOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: DSEPlatformOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\5b39b3b0\00f5cd24_833cd901\DSEPlatformOpen.dll
Loaded: DSEPlatformOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: DSEDesignWorkflowOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\bac77df8\001f433a_833cd901\DSEDesignWorkflowOpen.dll
Loaded: DSEDesignWorkflowOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: AmMaterialsOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\de789666\006b7e35_833cd901\AmMaterialsOpen.dll
Loaded: AmMaterialsOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: BaseChecker, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\e85d5d92\00d6c32a_833cd901\BaseChecker.dll
Loaded: BaseChecker, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: AnimationDesignerOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\6bd0bd54\00f21139_833cd901\AnimationDesignerOpen.dll
Loaded: AnimationDesignerOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: RuleOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\a992bc0b\005681c0_0cd7d701\RuleOpen.dll
Loaded: RuleOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: MfgMlpOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\a92fc928\004f3027_833cd901\MfgMlpOpen.dll
Loaded: MfgMlpOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: MPAOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\80b34191\006ebb80_0ed7d701\MPAOpen.dll
Loaded: MPAOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: PressLineSimulationOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\832a4de0\0079a53c_833cd901\PressLineSimulationOpen.dll
Loaded: PressLineSimulationOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: TDPOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\20804225\006ddc8a_0cd7d701\TDPOpen.dll
Loaded: TDPOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: DSEOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\243b784f\00410920_833cd901\DSEOpen.dll
Loaded: DSEOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: MoldCoolingOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\64d2eb65\00e95ed5_0ed7d701\MoldCoolingOpen.dll
Loaded: MoldCoolingOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: CLDCommonOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\641eda69\009b6b22_833cd901\CLDCommonOpen.dll
Loaded: CLDCommonOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: mfgamopen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\fe2e8b75\00b7b930_833cd901\mfgamopen.dll
Loaded: mfgamopen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: PIDOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\668df1e2\004c743b_833cd901\PIDOpen.dll
Loaded: PIDOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: CLDKinOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\066036c0\005d572e_833cd901\CLDKinOpen.dll
Loaded: CLDKinOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: ToolDesignerOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\7d2ce666\004c743b_833cd901\ToolDesignerOpen.dll
Loaded: ToolDesignerOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: MfgModelOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\04c9f48c\008a882f_833cd901\MfgModelOpen.dll
Loaded: MfgModelOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: SafetyOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\b0e81134\0003f52b_833cd901\SafetyOpen.dll
Loaded: SafetyOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: JoinOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\3e2b4e9b\004f3027_833cd901\JoinOpen.dll
Loaded: JoinOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: AtsUnitTestDotNet, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\04ae0d9a\00c89c23_833cd901\AtsUnitTestDotNet.dll
Loaded: AtsUnitTestDotNet, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: FalconOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\cbda58a8\00f5cd24_833cd901\FalconOpen.dll
Loaded: FalconOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: LineDesignerOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\74ba9004\00a99229_833cd901\LineDesignerOpen.dll
Loaded: LineDesignerOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: AMEOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\dcf42dda\0064c810_04e4d801\AMEOpen.dll
Loaded: AMEOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: CoatingsOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\af2f234f\00b2474c_0ed7d701\CoatingsOpen.dll
Loaded: CoatingsOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: StageModelOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\ba194754\00b03d25_0fd7d701\StageModelOpen.dll
Loaded: StageModelOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: DMUOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\b939ed20\00410920_833cd901\DMUOpen.dll
Loaded: DMUOpen, Version=2027.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded assembly: MBDOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from C:\Users\mauj7\AppData\Local\assembly\dl3\V5Y42514.50T\Y0MQ7MAL.TYW\785cf46a\007b0392_0cd7d701\MBDOpen.dll
Loaded: MBDOpen, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Unloading C:\Program Files\Siemens\NX2007\nxbin\managed\NXOpen.Utilities.dll
Journal execution results for C:\personalizzazioni_nx\Cambio_cdf_a_tutte_le_parti_sostituire_il_nome_cdf_dentro_CP.cs...
Execution was successful.
Compile Warnings:
Line 31: Warning: The variable 'e' is declared but never used
Line 92: Warning: The variable 'myStream' is assigned but its value is never used
&MACRO ASK_ITEM 4 (1 LIST 5707) = 1 ! List
&MACRO POSITION = 0 "C:\personalizzazioni_nx\Cambio_cdf_a_tutte_le_parti_sostituire_il_nome_cdf_dentro_CP.cs" ! Index/contents of selected item
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR <RibbonFileBar->BackStageBar->LeftBackStageGroup->rbn_file_tab_help_cascade.csb> ## !
and soon NX 2406
According to the log file, the journal executed with no issues. Is it possible that the colors in the part already match those in the external CDF file, causing no change in the part file? If not, I'd suggest contacting Siemens support with your files so they can have a look.
No the colors don't match
and usualy on the computer where the program
work, I can see the program open all the files
(and change the colors).
I have contacted the support (ItalY)
They say that the "program" is not from NX
and they can't do nothing.
If you suggest that it should work or at least
report something, I could insist (with the Siemens support).
and soon NX 2406
If the journal works on the old computer with NX2007, but does NOT work on the new computer with NX2007 that indicates that it is a configuration issue and not necessarily an NX or journal code issue. Do you still have access to the old computer to check its settings? If so, here are a few ideas in no particular order:
[ul]
[li]Check the encoding of the external CDF file. The CDF files are plain text and can be encoded in several different formats (ASCII, UTF-8, etc). I suggest using notepad++ (a free text editor) to check and convert the format, if necessary. If the CDF file has non-ASCII characters in it and it was copied over to the new computer as an ASCII file, the journal may not be able to interpret the characters properly.[/li]
[li]Similarly, check the journal file format (user interface preferences -> journal) and set it accordingly. I think this only affects the output format of the recorded journal text files, but can't hurt to make them the same.[/li]
[li]Check the version of the .net framework installed on each computer. The proper framework version should have been installed as part of the NX install, but again, it can't hurt to check.[/li]
[li]Check the "regional" settings of each computer in the Windows control panel. The journal reads values from a text file and converts them to numbers (doubles). Unless told otherwise, the .net framwork will convert them according to the current regional settings. The NXOpen API seems to expect numbers in the US format, if your regional settings are set to something else, you might need to modify the journal code to output the expected format.[/li]
[/ul]
Finally, if none of the above works, contact your local support and request that they escalate it to Siemens support. I've done this on a few occasions when I couldn't get an API function to work for me. Siemens support was very helpful in my cases.
cowksy THANKYOU WERY MUCH.
I have change the regional setting were
I had "," and I changed it to "."
and now the program work greate !!!
and soon NX 2406
