In NFPA 79 the color code states the following: BLACK - will be for line circuits, RED - will be for AC control circuits, at less then line voltage.
My question is this...can RED wire be used in circits that have the same voltage as the line voltage? Example: if I have a 3 phase system (let's say 208), and I tap off on one of the legs (L1) to a fuse. Does that branch color stay BLACK or RED below that fuse.
