Column Bracing Help
asalisbury
13
I'd like to preface this post by saying that I am not a structural engineer and am new to these topics.
I have a single column that has a very small radius of 0.13". It is supported laterally through a 0.30" thick plate with a 0.30" diameter hole through it. The plate moves up and down over the column. I am considering making the plate structural and in the realm of 2.5" thick. The column moves freely inside of the hole, but at times it can fetch. The column goes through a series of these plates that are in static condition above the moving plate. The column is fixed at its base. See diagram below.
What should I consider changing this plate over to be thicker? I am considering the potential of breaking the column when the moving plate could fetch (see second image).
wrong forum for this. probably belongs in the Mech Eng forum.
what is this thing? what are the design requirements?
