ticas
- Feb 4, 2013
- 102
a building has columns with ties distance 100mm (4") apart with close ties. But in the construction in the ground floor columns, one of the hooks are not bent 135 degrees but just 90 degrees (it is corrected in second to fourth floor which is the maximum storey). What kind of column retrofit can make it perform equal to the hook bent 135 degrees. Can putting flat bars around the finished column distance 4" apart do the trick or even using pure metal plate and welding them at the sides?? Who has encountered this before?
