Combination structural support/Linear bearing 3
SBMerrick
11
I'm designing a lifting device with about 10 feet of vertical motion and with a load capacity of about 2 tons. I would like to use the four support columns themselves as linear bearing guides for the vertical motion. I'm envisioning C-channel columns constraining roller or slide bearings. Any ideas on the best way to find or fabricate the columns? Any problems with the idea?
Thanks!
Steve
SBMerrick,
Your describing a fork lift mast if you want only 2 supports. If you need 4 supports use (2) masts.
Bill
Thanks for the quick response, Bill. Yes, I'd thought of forklift masts too, but couldn't find a source on line. I found plenty of bearings, but no source for the c-channel guides. Any guidance as to potential sources would be appreciated.
Thanks again,
Steve
I used to work for Allis-Chalmers where the rough terrain fork lift was built. We built masts up to 32' height with 5000 lb capacity with I believe 4 sections. They used some specialty rolled channels. I'm not sure where they got those products. I'm sure your local service center can give you guidance of who supplies this type of material and what they can get. You're are probably stuck with using stock sizes of channel because of low usage.
I hope this helps,
Bill
Winkle is one source for forklift mast and bearings.
Barry1961
Thanks, Barry. I tried to Google Winkle, and the closest match I found was for Winkle Industries who makes electromagnetic crane attachments. Is this the right company? If not, oculd you post a link?
Thanks!
Steve
The Winkle bearings look ideal for many of my applications. Thanks for the tip!
Dear Steve,
We are manufacturer of combined bearings in China.
I read your information,that you look for this kind of bearings.If you want,i can send you our catalogues for your reference.
It is also welcome to produce according to your samples and drawings.
Please contact me with: zybearing@vip.sina.com
Best Regards
Danny Zou
RUGAO WANDA SPECIAL BEARING CO.,LTD.
FAX:0086-513-7536087
Dear Every one,
We are manufacturer of combined bearings which Steve.
Who can help me with his contact information?
Danny Zou
Dear Every one,
We are manufacturer of combined bearings which Steve need.
Danny Zou
