Combined Creep and Fatigue Calculation in ASME BPVC 1
WIeli
Petroleum
Sep 16, 2024
Normally we are working against the PED in Europe but we have came across a problem which PED or EN13445 cant handle so i was trying to find a solution in ASME VIII. But i dont have much knownledge in ASME BPVC. And from what i can find for my problem is the same in ASME and PED.
We have an reactor that our client want to get made in 347H. The reactor have a design temp of 1150F, and the reactor needs to be calculated for fatigue. WHat i can find both in PED and ASME is fatigue calculation for Austenitic steel up to around 800F. But i cant find if there is any solution for fatigue calculation in the creep area. Is there anything in ASME that consider this? or maybe someone have encountered this before?
For Creep-Fatigue interaction, you would need to go to Section III, Division 5, Subsection HBB. Access to that from Section VIII, Division 2 is through Code Case 2843-2.
Thjank you for this. I will take a look an hopefully find a solution
