alphamaleomega
- Nov 30, 2004
- 7
I am working on an induction disc braking device that typically uses permanent magnets to create eddy currents and generate heat and drag, however, I desire to use a combination of electromagnet and permanent magnet for control purposes. The magnets are mechanically positioned to create a base drag then electromagnets are activated via pulse width modulation.
The c shape is made of 3.5" wide x 1/2" thick 8" long mild steel flat bar, each leg is welded to a 4" square tube, so the two legs are perpendicular to the square tube and separated by .5" + .5" + 9/16" or 1 9/16" apart.
The permanent magnets are mounted flush on the inside face of the flat bars so as to create an air gap of 9/16" between the magnets. The poles are opposite to one another. There are two 1.5" diameter x .5" permanent magnets on each leg, they are samarium cobalt permanent magnets.
I plan on winding the coils around the flat bar in the first 4" of the 8" bar. I desire low voltage high current, not that many windings 24V
I assume the permanent magnets will spread much of their field into the iron flat bars, the magnetic fields should be additive, the electro magnet flux plus the permanent magnet flux.
I need an Opra analysis of this magnetic circuit, but for preliminary design I am asking if my assumption on the fields being additive is valid and what losses would be incurred in the permanent magnets by being attached to the iron bars.
