SteveGregory
I have a one story Seismic Design Category D building with a steel beam/metal deck roof. I assume this is a flexible diaphram. The building is almost rectangular, but it has a couple of jogs in one corner.
For loads perpendicular to the long dimension wall, there are CMU shear/bearing walls on each end and one near the middle of the building. I will load these shear walls with the tributary widths for the wind and seismic loads.
For the loads perpendicular to the short dimension walls, there is a long CMU shear wall on one side. The other side is adjacent to an existing building that I don't want to make a structural attachment. So, we have a steel moment frame about 15' away from the existing bldg. The short dimension of the building is about 48' wide.
1. How should I go about distributing the wind and seismic loads between the moment frame and the shear walls?
2. Should 1/2 of weight of the CMU partition walls (4" to 8") contribute to the seismic load at the roof level?
