clarkoh
Automotive
- Feb 12, 2009
- 6
I started to make Stainless Steel exhaust/ turbo charger manifolds for the Cummins Turbo Diesel found in the Dodge pickups. I saw a prototype and the comments were that the use of this piece vs. the stock cast iron piece was a drop in exhaust gas temperatures by several hundred degrees F. The fabricator had used Schedule 10 stainless steel 1 1/2 inch elbows and pipe to make his piece. I have done the same on the manifold in the attached picture. Schedule 10 SS comes in 304 and 316 alloy. I have both available and made my first prototype from 304. So far so good. I have it on my test mule (2000 Ram 2500 2WD, with bigger than stock turbo and injectors and custom air box, 271,000 miles). One of the performance ss exhaust material suppliers suggests using 321 alloy for applications like mine. Exhaust gas temperatures can exceed 1400 F. I am wondering if using readily available, and reasonably priced schedule 10 304 or 316 alloy elbows makes sense? I have purchased some 2 inch .065 wall 321 tubing from the supplier. It allows me to build a much less restrictive manifold, is lighter in spite of being larger and seems to hold up fine. Comments?
Flying Hammer LLC a hot rod fabrication facility in Lincolnton, NC
