Revv
- Aug 23, 2021
- 87
Hey Guys So I'm working on a project where I basically want to frame out the building using steel I beams and columns and there are interior CFS walls that I want to be nonbearing but I want to hide my columns in them. Does anyone know of a commonly used detail for an I beam in line with the wall(above the wall) that the wall can attach to but not be bearing? Is this framing system common? I'm pretty new to steel work.
My only initial idea was to weld 2 symmetrical angles turned down to the bottom side of the bottom flange of the steel I beam. Then, add another track upside down on top of the regular track at cfs walls. Would connect the 2 back to back tracks together using screws in the center, then attack the bottom legs of the angles to the upward legs of the cfs tracks with screws with a washer in a vertically slotted hole. #1 I'm not sure this washer connection actually provides a nonbearing condition and #2 this seems pretty intricate.
