Common Source of Automotive Vibration? 1
rajin12
5
For any vehicle, where would you find the highest vibration?
I'm testing out an accelerometer that will be used to wake up electronics.
Isaac
The voltage varies when the alternator is charging as the engine runs.
I know modern Hondas s cut back the alternator voltage output once the battery is charged however I do not think that is common on other brands yet.
Pat
See FAQ731-376 for tips on use of eng-tips by professional engineers &
for site rules
The voltage also seems to get fairly high when it's hot out, but you're right - I was thinking just about the switching of the power supply to the socket, not how many volts would be read by the meter.
