Compact Expanding Gate Valves
jdalton
3
Hello.
Can anyone a valve manufacturer than can build a quality expanding gate valve, quality meaning that the seats will not leak and there will not be stem seal leaks within hours of being placed in operation?
"Compact Expanding Gate Valves"
Please explain what you are talking about.
prognosis: Lead or Lag
I made a mistake. I meant "Expanding Gate Valves". Like a WKM Pow-R-Seal.
Okay, now the next question:
"Can anyone a valve manufacturer than can build"
By this do you mean?
"Can anyone give me the name of one or more Valve manufacturers who can build ----"
Is that what you mean?
If so then Cameron Valves would be the best option.
Cameron is a leading provider of flow equipment products, systems and services to worldwide oil, gas and process industries. Leveraging its global manufacturing, engineering and sales and service network, Cameron works with drilling contractors, oil & gas producers, pipeline operators, refiners and other process owners to control, direct, adjust, process, measure and compress pressures and flows.
What is the application, there are expert manufacturers for specific applications.
