Compaction 95% MDD 3
boubasupreme
3
Hello Everyone,
can someone tell me how to know an area is 95% MDD Compacted?
You have to determine the in-place density by one of several field testing procedures. In the US, the more common method is the nuclear density test done in accordance with ASTM D6938, "Standard Test Method for In-Place Density and Water Content of Soil and Soil-Aggregate by Nuclear Methods (Shallow Depth)". This is a test that is done in the field after compaction is done.
The value of the in place density is then compared to a test run in the laboratory on a sample of soil from the site. This test is to determine the maximum dry density of the soil and its optimum moisture content. There are a couple of common methods for this test in the lab, most commonly the "Modified Proctor" version done in accordance with ASTM D1557. Once the maximum dry density is determined in the lab and the in place density is determined in the field, the two are compared by dividing the in place density by the maximum dry density to determine the percent compaction.
Basic construction materials testing.
Instead of going through all the steps yourself, it is commonly found that a materials testing laboratory does this as a major part of their business. Check locally for such help.
I like the sand cone method. Does anyone use that anymore? When using the sand cone, most contractors realize that ground vibrations from their earthmoving equipment can cause more sand to pack into the hole and give lower density readings. So when you walk onto the site carrying "the jug", all equipment would shut down and all equipment operators would freeze and watch you. Really gives one a feel of power to shut down all that equipment just by walking onto the jobsite.
Yes - we used in on my current project. We also used the nuke - I like the sand cone better.
I always found this a good compaction test method. The biggest guy on crew was told to stand on the tailgate of a pickup. When he jumps down, if you see an imprint re-compact.
Richard A. Cornelius, P.E.
Richard, you're not far off. I used to carry a piece of 2x4 sized to exert 1500 psf when I stood on it.
. . . and of course the old "heel test"
