compare two models
bullthot
Automotive
Dec 7, 2011
12
0
0
PL
Hello all,
I need to compare to solids which are saved in two files. I don`t know how can I do it, because if I will put it into assembly I suppoused I can`t do nothing.
The think which is important to me, is to find diffrents between this bodies.
thanks for advice to use Analysis and model compare. Yest this is good but not permanently. When I close the window I need do this analasys one more time. I want to have result for all time. It is possible to make this two parts in one part which will be intersection of them?
I don't see a reason why you couldn't do this manually.
Unite, subtract and intersect might help you out.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
Why don't you just do a File -> Import -> Part? Take file #2 and import it into file #1.
John Lackowski
NX Support
Win 7 64bit NX 7.5.4.4 TC 8.3.1.1
Careful with that. If these are native NX parts, you will end up with both part histories in the same file. That might be what you want, but more likely will just lead to a big mess. If model compare isn't good enough and you want to subtract or intersect the 2 parts, I would suggest using associative copies of the bodies (via promotions or wave links).
