Awais Arshad
Hi all,
We have a case where the mating flange has different surface finish compared to the top flange; one flange has a surface finish value of Ra 3.2-6.3 um, while the other has a surface finish value of 1.6 um.
As per my literature research, the SPW gasket works find under such configuration. Still, being a forum of expert engineers, will appreciate if the members can shed light on the case i.e. if a Spiral Wound Gasket will operate or work fine @ DP = 35 kg/cm2g & DT= 220 dC under different flange surface finishes as mentioned earlier.
Awais
Awais
