compile .VB jornal without visual studio
NXJockey
Automotive
Feb 9, 2009
104
I have a simple journal file:-
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim theUI As UI = UI.GetUI()
msgbox("Hello World")
End Sub
End Module
Is it possible to compile this into a signed EXE, DLL etc. without visual studio and only using .net framework and the local install of NX (11 in my case)
Thanks in advance.
Cheers,
NXJ
I'm guessing there would be open source compilers available (I found a few using Google)
To be able to Sign the resulting exe or dll sou also need to add (as a resource) the correct NXSigningResource.res to you project.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Yes.
There is a command line syntax in
In nx document.
Make a search "compile"
Something like this
C:\WINDOWS\Microsoft.NET\Framework\v3.5\vbc /libpath:"C:\Program Files\Siemens\NX 11.0\NXBIN\managed" /t:library /r:NXOpen.dll /r:NXOpen.Utilities.dll /r:NXOpen.UF.dll /r:NXOpenUI.dll your.vb
Worked perfectly,
Many thanks,
NXJ
