Complexity Factor/Index Limitations
drewpy
Petroleum
Jul 6, 2007
Can anyone provide thoughts on limitations of using complexity factors/indexes for comparing refineries? I am sure I saw an article on this recently but can not find it now. Thanks
Hi, I am thinking about complexity indexes/factors which are used to compare refineries on a cost per complexity barrel basis. The article I saw basically said, "there are limitations on comparing refineries on a cost per complexity barrel, because the same index value is given to unit processes which have significantly different functions".
drewpy
Sorry, I can speak for days on factored cost estimates, but have not been involved in the type you are referring to nor did I see the article.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website:
Thanks to all for the above information.
Yes you are true that normal HDS feed doesn't contain any elemental S , but this feed is from a condensate refinery which contain elemental sulfur in dissolved form.
