NayanDeshmukh
Automotive
I built a full-vehicle model making minor changes to the in-built macpherson strut template. The model runs fine on the SDI testrig but gives me a 'Compliance matrix calculation failed' error on SPMM testrig.
On SPMM, the SVC is simulated and then the Solver carries out 4-5 iterations before showing the compliance matrix error.
(1) I have compliance mode active for all the subsystems assembled in the full vehicle
(2) Hub compliance is active
(3) The characteristic array in suspension parameters is defined using the geometric method using lower control arm outer point and top strut mount
I am attaching the .msg file for my failed SPMM test run. Can someone please help me with this error?
