Component Creator - with Smart Sorting feature 2
lj1970
Marine/Ocean
Nov 26, 2023
18
Hello everyone,
I'd like to introduce my latest creation: Captain Hook's Component Creator. Infused with a touch of nautical flair, this tool is designed to streamline the process of component creation within Siemens NX, locally and when integrated with Teamcenter environments.
Under the Hood:
- Local: The tool searches for the first sequential component labeled "-101". It then generates the next available component number. These components aren't saved; they are created for you to save if you are satisfied with the outcome. The journal searches through your library, session, and memory for the component name you have set, checking for available or missing numbers to avoid duplication. The names for the components will be derived from the names of the solid bodies. If a solid body does not have an assigned name, the default name “Panel” will be used.
- Teamcenter: The tool employs a two-round approach to ensure each component is sequentially numbered and accurately tracked in Teamcenter. You can use both the first and second rounds or only the second, depending on your requirements.
Round One: Sets and saves an initial ID number, anchoring the starting point for a sequence.
Round Two: Uses a substitute wildcard number to generate subsequent IDs, which requires experimenting with formats like "*" (star).
Features:
- Smart Sorting: Utilizes EasyWeight or NX's built-in material attributes to sort solid bodies by material name and weight in descending order or retains the order of your initial selection.
- Unit Support: Adapts to both metric (millimeters) and imperial (inches) units within material names.
- EasyWeight Integration: Updates all weight information before component creation with automatic recognition of the unit system.
- Configuration Settings with detailed descriptions at the beginning of the Journal: WaveLink options, flagging created components to avoid duplication, controlling numbering gaps for local environment and Teamcenter option.
This tool is ideal for mechanical engineers and designers using Siemens NX who require an automated method to create components in complex assemblies, particularly beneficial in large-scale projects.
The journal has been thoroughly tested on Siemens NX 2212 and 2306 and is designed for easy customization to fit specific project requirements. For more detailed examples and configuration settings see comments at the beginning of the journal.
Happy designing!
Shared on NXJournaling.com:
Link
and on GitHub:
Link
Code:
' Written by Tamas Woller - February 2024, V103
' Journal desciption: Automatically create parts by requesting you a main component name. Select solid bodies to create components for.
' Shared on NXJournaling.com
' Written in VB.Net
' Tested on Siemens NX 2212 and 2306, Native and Teamcenter 13
' V100 - Initial Release - January 2024
' V101 - Body flag system Fix
' V103 - Smart Sorting with EasyWeight or NX's built-in material attributes, Metric (Millimeters) and Imperial (Inches) unit support in Material name, WaveLink Option, Flag Created Components Option, Control Numbering Gaps Option and added Configuration Settings
' V105 - Added notes and minor changes in Output Window
' V107 - Update EasyWeight's EW_Body_Weight attribute before sorting
' V109 - Added 'Maybe' to sorting
' V111 - TC with custom numbering
Imports System
Imports NXOpen
Imports System.Collections.Generic
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.Windows.Forms
Imports System.Text.RegularExpressions
Module NXJournal
	Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
	Dim theUFSession As NXOpen.UF.UFSession = NXOpen.UF.UFSession.GetUFSession()
	Dim workPart As NXOpen.Part = theSession.Parts.Work
	Dim mainAssembly As Part = If(workPart.ComponentAssembly.RootComponent IsNot Nothing, workPart.ComponentAssembly.RootComponent.Prototype, workPart)
	Dim unitString As String = "mm"
	Dim displayPart As NXOpen.Part = theSession.Parts.Display
	Dim theUI As NXOpen.UI = NXOpen.UI.GetUI()
	Dim logicalobjects1() As NXOpen.PDM.LogicalObject = Nothing
	Dim logicalobjects2() As NXOpen.PDM.LogicalObject = Nothing
	Dim sourceobjects1() As NXOpen.NXObject
	Dim selectedObjectName As String
	Dim mySelectedObjects As New List(Of DisplayableObject)
	Dim lw As ListingWindow = theSession.ListingWindow
	Dim nXObject2 As NXOpen.NXObject = Nothing
	Dim lldirectoryPath As String
	Dim materialName As String
	Dim bodyWeight As Double
    Dim smartsortingfeature As Boolean
	Dim assemblyid As String
	' Configuration Settings:
	' Default Assembly ID name
	Dim defaultassemblyid As String = "MyProject-01"
	' WaveLink Feature - True or False
	Dim wavelinkfeature As Boolean = True
	' Smart Sorting - This feature sorts the selected bodies by their material name in descending order. It first considers the initial numerical value found in the material name before the unit (for example, the "12" in "12mm Plywood"). If no numerical value is present, sorting is done alphabetically. Should multiple bodies share the same material, they are then sorted by weight in descending order.
	' You'll receive feedback on Material name and weight, so you understand the order presented.
	' If it False, it will preserve the order in which you initially clicked on the bodies for selection. - "True", "False" or "Maybe"
	Dim smartsortingfeatureQST As String = "Maybe"
	' This setting is particularly useful when utilizing the smart sorting feature, as it helps break down material names into segments for efficient sorting and organization. For instance, a material named '12mm Plywood' would be divided at 'mm', allowing the code to sort solids effectively.
	' You can adjust settings for "mm" (Millimeter) and "in" (Inch) to whatever you use to describe your materials based on your preferred unit system. Let's say, you are naming your solid bodies like "3/4 Inch Plywood" - then you would change 'ssunitin' to "Inch".
	' The journal handles whole or decimal numbers (e.g., "12", "12.5") and fractions specifically for inches (e.g., "1/2"). It automatically adjusts these values by multiplying them by 25.4 to ensure consistency in sorting, allowing you to safely use any of these variants within the same workflow.
	Dim ssunitmm As String = "mm"
	Dim ssunitin As String = "in"
	' Sorting logic use EasyWeight (True) or NX Built-in Material (False) attributes. - True or False
	Dim EasyWeightsortinglogic As Boolean = False
	' Default Solid Body Name - Assigns a name to any solid body that lacks one, ensuring all bodies are identifiable.
	' You can set these names under Reference Sets.
	' If you can't see this folder, click on a empty space in Part Navigator / uncheck Timestamp Order OR File / Utilities / Customer Defaults / Gateway / Part Navigator / Display Reference Sets Folder.
	Dim defaultsolidbodyname As String = "PANEL"
	' Flag Created Components - To prevent duplicating efforts, this option tags processed solid bodies with a 'Component created' attribute. It's an efficient way to track which bodies have already been processed.
	' If you want to override this later, simply delete the value of this attribute in Solid body / Properties. - True or False
	Dim setcomponentflag As Boolean = False
	' Teamcenter Integration Settings - Determines whether the journal operates locally "False" or integrates with Teamcenter. Selecting "Maybe" prompts a question at the start to finalize this setting, tailoring the journal to your specific workflow needs. - "True", "False" or "Maybe".
	' If you are using this locally, you will be prompted at the beginning to specify where you want to save your files. If you leave it empty and hit enter, it will use the specified default directory (lldefaultdirectoryPath).
	Dim teamcenterIntegrationQST As String = "False"
	' Control Numbering Gaps - Only for Local - This feature enables intelligent handling of component numbering. For instance, if you initially create components numbered 101, 102, 103, 104, and 105, but later delete 101 and 103, activating this option will prioritize filling these gaps with new components before proceeding to increment the numbers. It's an efficient method to maintain a continuous sequence and optimize the utilization of available numbers.
	' Remember, when removing components, it's important not only to remove them from the assembly but also to close them using File / Close / Selected Parts. This ensures they are removed from memory as well.
	' Additionally, if you are working locally and have saved these parts, you should also delete them from the file system to avoid clutter. - True or False
	Dim fillTheGap As Boolean = True
	' IMPORTANT! Record a Journal first in - Visual Basic (*.vb) - by Developer / Record with Assemblies / New Component. Complete the entire process of creating a new component, then stop the recording. In your saved file, you'll find the following variants (note that prefixes such as 'tc', 'll', and 'wl' won't be included) - the matching words are highlighted:
	' partOperationCreateBuilder1.DEFAULTDESTINATIONFOLDER, fileNew1.TEMPLATEFILENAME, fileNew1.UNITS, fileNew1.RELATIONTYPE, fileNew1.TEMPLATEPRESENTATIONNAME and fileNew1.ITEMTYPE.
	' Copy paste the values.
    ' Explanation and ID numbering for First and Second Rounds:
	' The journal is prepared to follow two different logics in Teamcenter. Let me know if you have a specific case:
	' Situation One: Non-specific numbering, following system sequence.
	' Goal: Invoke a substitute ID usable in the journal.
	' Example: If a new component ID is 160379, try creating another with a substitute ID of 16000* (modify the last digit to "*"). If Teamcenter generates the next available number from 160000, we have found what we were looking for.
	' Settings:
	' Dim defaultassemblyid As String = "16000*" ' Set our base or default assembly ID.
	' Dim assemblyidQST As Boolean = False ' Set to False as the ID follows the previous number without query.
	' Dim tcwithtworounds as Boolean = False ' The base - 160000 - is already created, so the first round is unnecessary. Only the second round will use the default ID as a wildcard.
	' Dim tcfirstround as String = "" ' Not relevant as the first round is skipped.
	' Dim tcsecondround as String = "" ' Should be empty since the default ID is set initially.
	' Situation Two: Specific assembly numbers are needed, similar to local logic.
	' Example: After creating and saving "X184-500-101" as the first component, attempt the next one with "X184-500-10*". If TC automatically generates the next number from 101, it's successful.
	' Settings:
	' Dim defaultassemblyid As String = "MyProject-01" ' Not relevant here since input is always requested.
	' Dim assemblyidQST As Boolean = True ' Set to True to always ask for the base specific assembly ID number on each run. Input example: X184-500.
	' Dim tcwithtworounds as Boolean = True ' TC requires a base number to be SAVED first (X184-500-101), allowing it to automatically generate subsequent numbers and create follow-up components in the second. (X184-500-102, etc.).
	' Dim tcfirstround as String = "-101" ' This is the number appended to the first round.
	' Dim tcsecondround as String = "-10*" ' This is the number appended to the second round.
	' TC Settings
	Dim tcDefaultDestinationFolder As String = ":NewFolder"
	Dim tcTemplateFileName As String = "@DB/GT_mm_template/01"
	Dim tcUnits As NXOpen.Part.Units = NXOpen.Part.Units.Millimeters
	Dim tcRelationType As String = "master"
	Dim tcTemplatePresentationName As String = "Model"
	Dim tcItemType As String = "Item"
	' Local Settings
	Dim llTemplateFileName As String = "model-plain-1-mm-template.prt"
	Dim llUnits As NXOpen.Part.Units = NXOpen.Part.Units.Millimeters
	Dim llTemplatePresentationName As String = "Model"
	Dim lldefaultdirectoryPath As String = "C:\NXPartsFolder\"
    Dim llnextAvailableId As Integer = 101
	' WaveLink Settings
	Dim wlAssociative As Boolean = True
	Dim wlFixAtCurrentTimestamp As Boolean = False
	Dim wlHideOriginal As Boolean = True
	Dim wlInheritDisplayProperties As Boolean = True
	Dim wlMakePositionIndependent As Boolean = True
	Dim wlCopyThreads As Boolean = True
	Sub Main(ByVal args() As String)
		lw.Open()
		theSession = Session.GetSession()
		theUFSession = UFSession.GetUFSession()
		workPart = theSession.Parts.Work
		displayPart = theSession.Parts.Display
		theUI = UI.GetUI()
		Dim isFirstSave As Boolean = True
		lw.WriteLine("------------------------------------------------------------")
		lw.WriteLine("Captain Hook's Component Creator          Version: 1.11 NXJ ")
		lw.WriteLine(" ")
		lw.WriteLine("--------------------------------")
		lw.WriteLine("Configuration Settings Overview:")
		lw.WriteLine(" ")
		lw.WriteLine(" - WaveLink Feature:           " & If(wavelinkfeature, "Yes", "No"))
        If smartsortingfeatureQST IsNot Nothing AndAlso (smartsortingfeatureQST.Equals("True", StringComparison.OrdinalIgnoreCase) OrElse smartsortingfeatureQST.Equals("False", StringComparison.OrdinalIgnoreCase)) Then
			smartsortingfeature = Boolean.Parse(smartsortingfeatureQST)
		Else
			Dim userResponse As DialogResult = MessageBox.Show("Do you wish to enable Smart Sorting for Components?", "Smart Sorting", MessageBoxButtons.YesNoCancel)
			Select Case userResponse
				Case DialogResult.Yes
					smartsortingfeature = True
				Case DialogResult.No
					smartsortingfeature = False
				Case DialogResult.Cancel
					lw.WriteLine(" ")
					lw.WriteLine("Abandon ship! We're departing the logbook.")
					Return
			End Select
		End If
		lw.WriteLine(" - Smart Sorting:              " & If(smartsortingfeature, "Yes", "No"))
		If smartsortingfeature Then
			If EasyWeightsortinglogic Then
				lw.WriteLine("   With EasyWeight attributes")
			Else
				lw.WriteLine("   With NX Built-in attributes")
			End If
		Else
			lw.WriteLine("   Follow the selection order")
		End If
		lw.WriteLine(" - Component Created flag:     " & If(setcomponentflag, "Yes", "No"))
		Dim teamcenterIntegration As Boolean = False
		If teamcenterIntegrationQST IsNot Nothing AndAlso (teamcenterIntegrationQST.Equals("True", StringComparison.OrdinalIgnoreCase) OrElse teamcenterIntegrationQST.Equals("False", StringComparison.OrdinalIgnoreCase)) Then
			teamcenterIntegration = Boolean.Parse(teamcenterIntegrationQST)
		Else
			Dim userResponse As DialogResult = MessageBox.Show("Are you working with Teamcenter?", "Teamcenter Integration", MessageBoxButtons.YesNoCancel)
					teamcenterIntegration = True
					teamcenterIntegration = False
					lw.WriteLine(" ")
					Return
			End Select
		End If
		lw.WriteLine(" - Teamcenter integration:     " & If(teamcenterIntegration, "Yes", "No"))
		If Not teamcenterIntegration Then
			Dim userInput As String = InputBox("Where would you like to save your files? - etc. C:\NXPartsFolder\", "Directory Path")
			lldirectoryPath = If(String.IsNullOrWhiteSpace(userInput), lldefaultdirectoryPath, userInput)
			If Not lldirectoryPath.EndsWith("\") Then
				lldirectoryPath &= "\"
			End If
			' Check if the directory exists
            If Not System.IO.Directory.Exists(lldirectoryPath) Then
				Try
					System.IO.Directory.CreateDirectory(lldirectoryPath)
					lw.WriteLine("   Folder has been created.    ")
				Catch ex As UnauthorizedAccessException
					lw.WriteLine(" ")
					lw.WriteLine("Stop the presses! Permission to construct the Folder be refused: " & lldirectoryPath)
					lw.WriteLine("Pirate's Proclamation: " & ex.Message)
					Return
				Catch ex As System.IO.PathTooLongException
					lw.WriteLine(" ")
					lw.WriteLine("Arr, the map stretches further than the eye can see: " & lldirectoryPath)
					Return
				Catch ex As Exception
					lw.WriteLine(" ")
					lw.WriteLine("Alas, the winds are not in our favor to form the specified Folder: " & lldirectoryPath)
					Return
				End Try
			End If
		End If
		' Perform the unit check on the main assembly
		If mainAssembly.PartUnits = BasePart.Units.Inches Then
			unitString = "in"
			lw.WriteLine(" - Main Assembly Unit System:  Imperial (Inches)")
		Else
			unitString = "mm"
			lw.WriteLine(" - Main Assembly Unit System:  Metric (Millimeters)")
		End If
			lw.WriteLine(" - Save to:                    " & lldirectoryPath)
			lw.WriteLine(" - Fill the gaps in numbers:   " & If(fillTheGap, "Yes", "No"))
		End If
		lw.WriteLine(" - Default Solid Body name:    " & defaultsolidbodyname)
		If assemblyidQST Then
			assemblyid = InputBox("Please enter your required ID Name - etc. MyProject-01", "Component Creator")
			If String.IsNullOrEmpty(assemblyid) Then
					assemblyid = defaultassemblyid
				Else
					lw.WriteLine(" ")
					Exit Sub
				End If
			End If
		Else
		End If
		lw.WriteLine(" - Base of AssemblyID:         " & assemblyid)
		lw.WriteLine("---------------------")
		lw.WriteLine(" ")
		selectedObjectName = SelectObjects("Hey, select multiple somethings", mySelectedObjects)
		Dim markId1 As NXOpen.Session.UndoMarkId
		markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Component Creator")
		Dim nXObject1 As NXOpen.NXObject = Nothing
		Dim mySolid As New List(Of Body)
		Dim baseAssemblyId As String = assemblyid & "-"
		Dim idPart As Integer
		Dim usedIds As New SortedSet(Of Integer)()
            ' Get the IDs from existing files in the directory
			For Each file As String In System.IO.Directory.GetFiles(lldirectoryPath, baseAssemblyId & "*")
				Dim fileName As String = System.IO.Path.GetFileNameWithoutExtension(file)
				If fileName.StartsWith(baseAssemblyId) Then
					Dim idString As String = fileName.Substring(baseAssemblyId.Length).TrimStart("-"c)
					Dim parts As String() = idString.Split("-"c)
					If parts.Length > 0 AndAlso Integer.TryParse(parts(0), idPart) Then
						usedIds.Add(idPart)
					End If
				End If
			Next
			' Get the IDs from components in the NX session that haven't been saved yet
            If workPart.ComponentAssembly.RootComponent IsNot Nothing Then
				For Each comp As Component In workPart.ComponentAssembly.RootComponent.GetChildren()
					Dim compName As String = comp.DisplayName
					If compName.StartsWith(baseAssemblyId) Then
						Dim idString As String = compName.Substring(baseAssemblyId.Length).TrimStart("-"c)
							usedIds.Add(idPart)
						End If
					End If
				Next
			End If
			' Find the first available ID (filling in the gaps)
            If fillTheGap Then
				While usedIds.Contains(llnextAvailableId)
					llnextAvailableId += 1
				End While
			Else
				' If not filling the gap, find the highest ID and add 1
                If usedIds.Count > 0 Then
					llnextAvailableId = usedIds.Max + 1
				End If
			End If
		End If
		For Each tempComp As DisplayableObject In mySelectedObjects
			mySolid.Add(CType(tempComp, Body))
			Dim attributePropertiesBuilder1 As NXOpen.AttributePropertiesBuilder = Nothing
			Dim createNewComponentBuilder1 As NXOpen.Assemblies.CreateNewComponentBuilder = Nothing
			Dim AssemblyidString As String = assemblyid & tcfirstround
			Dim body As Body = CType(tempComp, Body)
			selectedObjectName = body.Name
			If setcomponentflag Then
				If IsComponentCreated(body) Then
					lw.WriteLine(" ")
					lw.WriteLine(" - This solid body already has a component: " & selectedObjectName)
					Continue For
				End If
			End If
			If String.IsNullOrEmpty(selectedObjectName) Then
				Continue For
			End If
			If teamcenterIntegration Then
				If tcwithtworounds Then
					Try
						Dim fileNew1 As NXOpen.FileNew = theSession.Parts.FileNew()
						Dim partOperationCreateBuilder1 As NXOpen.PDM.PartOperationCreateBuilder = Nothing
						partOperationCreateBuilder1 = theSession.PdmSession.CreateCreateOperationBuilder(NXOpen.PDM.PartOperationBuilder.OperationType.Create)
						fileNew1.SetPartOperationCreateBuilder(partOperationCreateBuilder1)
						partOperationCreateBuilder1.SetOperationSubType(NXOpen.PDM.PartOperationCreateBuilder.OperationSubType.FromTemplate)
						partOperationCreateBuilder1.SetModelType("master")
						partOperationCreateBuilder1.SetItemType("Item")
						partOperationCreateBuilder1.CreateLogicalObjects(logicalobjects1)
						sourceobjects1 = logicalobjects1(0).GetUserAttributeSourceObjects()
						partOperationCreateBuilder1.DefaultDestinationFolder = tcDefaultDestinationFolder
						fileNew1.TemplateFileName = tcTemplateFileName
						fileNew1.Units = tcUnits
						fileNew1.RelationType = tcRelationType
						fileNew1.TemplatePresentationName = tcTemplatePresentationName
						fileNew1.ItemType = tcItemType
						fileNew1.UseBlankTemplate = False
						fileNew1.ApplicationName = "ModelTemplate"
						fileNew1.UsesMasterModel = "No"
						fileNew1.TemplateType = NXOpen.FileNewTemplateType.Item
						fileNew1.Specialization = ""
						fileNew1.SetCanCreateAltrep(False)
						partOperationCreateBuilder1.SetAddMaster(False)
						partOperationCreateBuilder1.CreateLogicalObjects(logicalobjects2)
						Dim nullNXOpen_BasePart As NXOpen.BasePart = Nothing
						Dim objects1(-1) As NXOpen.NXObject
						attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(nullNXOpen_BasePart, objects1, NXOpen.AttributePropertiesBuilder.OperationType.Create)
						Dim objects2(-1) As NXOpen.NXObject
						attributePropertiesBuilder1.SetAttributeObjects(objects2)
						Dim objects3(0) As NXOpen.NXObject
						objects3(0) = sourceobjects1(0)
						attributePropertiesBuilder1.SetAttributeObjects(objects3)
						attributePropertiesBuilder1.Title = "DB_PART_NO"
						attributePropertiesBuilder1.Category = "Item"
						attributePropertiesBuilder1.StringValue = AssemblyidString
						Dim changed1 As Boolean = Nothing
						changed1 = attributePropertiesBuilder1.CreateAttribute()
						Dim attributetitles1(-1) As String
						Dim titlepatterns1(-1) As String
						nXObject1 = partOperationCreateBuilder1.CreateAttributeTitleToNamingPatternMap(attributetitles1, titlepatterns1)
						Dim objects4(0) As NXOpen.NXObject
						objects4(0) = logicalobjects1(0)
						Dim properties1(0) As NXOpen.NXObject
						properties1(0) = nXObject1
						Dim errorList1 As NXOpen.ErrorList = Nothing
						errorList1 = partOperationCreateBuilder1.AutoAssignAttributesWithNamingPattern(objects4, properties1)
						errorList1.Dispose()
						attributePropertiesBuilder1.Title = "DB_PART_NAME"
						attributePropertiesBuilder1.StringValue = selectedObjectName
						Dim changed2 As Boolean = Nothing
						changed2 = attributePropertiesBuilder1.CreateAttribute()
						fileNew1.MasterFileName = ""
						fileNew1.MakeDisplayedPart = False
						fileNew1.DisplayPartOption = NXOpen.DisplayPartOption.AllowAdditional
						partOperationCreateBuilder1.ValidateLogicalObjectsToCommit()
						Dim logicalobjects4(0) As NXOpen.PDM.LogicalObject
						logicalobjects4(0) = logicalobjects1(0)
						partOperationCreateBuilder1.CreateSpecificationsForLogicalObjects(logicalobjects4)
						' Create new component
						createNewComponentBuilder1 = workPart.AssemblyManager.CreateNewComponentBuilder()
						createNewComponentBuilder1.ReferenceSetName = "MODEL"
						createNewComponentBuilder1.ComponentOrigin = NXOpen.Assemblies.CreateNewComponentBuilder.ComponentOriginType.Absolute
						createNewComponentBuilder1.OriginalObjectsDeleted = False
						createNewComponentBuilder1.ObjectForNewComponent.Clear()
						'Non Wavelink add body
                        If Not wavelinkfeature Then
							createNewComponentBuilder1.ObjectForNewComponent.Add(body)
							'lw.WriteLine("   Solid body added successfully.")
						End If
						createNewComponentBuilder1.NewFile = fileNew1
						nXObject2 = createNewComponentBuilder1.Commit()
						lw.WriteLine("")
						lw.WriteLine(" - First component for:   " & selectedObjectName & " created.")
						Dim bodyToAdd As NXOpen.Body = CType(body, NXOpen.Body)
								Try
									materialName = bodyToAdd.GetStringAttribute("EW_Material")
								Catch exInner As Exception
									materialName = "Not specified"
								End Try
								Try
									bodyWeight = bodyToAdd.GetRealAttribute("EW_Body_Weight")
									bodyWeight = -1
								End Try
							Else
								Try
									materialName = GetMaterialName(bodyToAdd)
								End Try
								Try
									bodyWeight = GetBodyWeight(bodyToAdd)
									bodyWeight = -1
								End Try
							End If
							lw.WriteLine(String.Format("   Material Name:         {0}", materialName))
							lw.WriteLine(String.Format("   Weight:                {0}", bodyWeight.ToString()))
						End If
						Dim newComponent As NXOpen.Assemblies.Component = TryCast(nXObject2, NXOpen.Assemblies.Component)
						Dim newComponentPart As Part = CType(newComponent.Prototype, Part)
						If wavelinkfeature Then
							' Change the work part to the new component's part
                            theSession.Parts.SetWork(newComponentPart)
							' Setup the WaveLinkBuilder in the new component's context
                            Dim waveLinkBuilder As Features.WaveLinkBuilder = newComponentPart.BaseFeatures.CreateWaveLinkBuilder(Nothing)
							waveLinkBuilder.Type = Features.WaveLinkBuilder.Types.BodyLink
							waveLinkBuilder.CopyThreads = False
							Dim extractFaceBuilder As Features.ExtractFaceBuilder = waveLinkBuilder.ExtractFaceBuilder
							extractFaceBuilder.FaceOption = Features.ExtractFaceBuilder.FaceOptionType.FaceChain
							extractFaceBuilder.ParentPart = Features.ExtractFaceBuilder.ParentPartType.OtherPart
							extractFaceBuilder.Associative = wlAssociative
							extractFaceBuilder.FixAtCurrentTimestamp = wlFixAtCurrentTimestamp
							extractFaceBuilder.HideOriginal = wlHideOriginal
							extractFaceBuilder.InheritDisplayProperties = wlInheritDisplayProperties
							extractFaceBuilder.MakePositionIndependent = wlMakePositionIndependent
							extractFaceBuilder.CopyThreads = wlCopyThreads
							Dim selectObjectList As SelectObjectList = extractFaceBuilder.BodyToExtract
							selectObjectList.Add(body)
							waveLinkBuilder.Commit()
							lw.WriteLine("   WaveLink added successfully.")
							waveLinkBuilder.Destroy()
						End If
						' Mark the original body as processed
							SetComponentCreated(body, True)
						End If
						theSession.Parts.SetWork(workPart)
						If isFirstSave Then
							Dim partSaveStatus As NXOpen.PartSaveStatus = Nothing
							Dim newPart As NXOpen.Part = CType(newComponent.Prototype, NXOpen.Part)
							Try
								partSaveStatus = newPart.Save(NXOpen.BasePart.SaveComponents.False, NXOpen.BasePart.CloseAfterSave.False)
							Catch ex As NXOpen.NXException
							End Try
							If partSaveStatus IsNot Nothing Then
								partSaveStatus.Dispose()
							End If
							lw.WriteLine("   Saved to Teamcenter:   " & AssemblyidString)
							'lw.WriteLine(" ")
							'lw.WriteLine("A friendly nudge: the remaining components are still drifting in the digital")
							'lw.WriteLine("ether, unsaved. Do cast an eye, delete, if the stars are out of alignment,")
							'lw.WriteLine("and proceed as the universe dictates.")
							isFirstSave = False
						Else
						End If
					Catch ex As Exception When ex.Message.Contains("The new filename is not a valid file specification")
						Dim markId2 As NXOpen.Session.UndoMarkId
						markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Component Creator")
						AssemblyidString = assemblyid & tcsecondround
						End If
						lw.WriteLine(" ")
						lw.WriteLine(" - Component created for: " & selectedObjectName)
								Try
								End Try
								Try
									bodyWeight = -1
								End Try
							Else
								Try
								End Try
								Try
									bodyWeight = -1
								End Try
							End If
						End If
						End If
						End If
						lw.WriteLine(" ")
						lw.WriteLine("Yo ho, mates, we've hit a snag... an error has marooned us: " & ex.Message)
						lw.WriteLine("Pirate's Proclamation: " & ex.StackTrace)
					Finally
						If createNewComponentBuilder1 IsNot Nothing Then
							createNewComponentBuilder1.Destroy()
						End If
						If attributePropertiesBuilder1 IsNot Nothing Then
							attributePropertiesBuilder1.Destroy()
						End If
					End Try
				Else
					Try
						End If
						lw.WriteLine(" ")
								Try
								End Try
								Try
									bodyWeight = -1
								End Try
							Else
								Try
								End Try
								Try
									bodyWeight = -1
								End Try
							End If
						End If
						End If
						End If
						lw.WriteLine(" ")
					Finally
						End If
						End If
					End Try
				End If
			Else
				' Setup for local (non-Teamcenter) environment
				Try
					' Construct the new file name with the next available ID
					Dim newFileName As String = lldirectoryPath & baseAssemblyId & llnextAvailableId.ToString("D3") & "-" & selectedObjectName & ".prt"
					Dim simpleFileName As String = baseAssemblyId & llnextAvailableId.ToString("D3") & "-" & selectedObjectName & ".prt"
					fileNew1.NewFileName = newFileName
					fileNew1.Units = llUnits
					fileNew1.TemplatePresentationName = llTemplatePresentationName
					fileNew1.AllowTemplatePostPartCreationAction(False)
					fileNew1.TemplateFileName = llTemplateFileName
					createNewComponentBuilder1.DefiningObjectsAdded = False
					createNewComponentBuilder1.NewComponentName = selectedObjectName.ToString
					createNewComponentBuilder1.DefiningObjectsAdded = True
					Dim bodyToAdd As NXOpen.Body = CType(tempComp, NXOpen.Body)
					lw.WriteLine(" ")
					lw.WriteLine(String.Format(" - Processing Body:      " & selectedObjectName))
							Try
							End Try
							Try
								bodyWeight = -1 ' Use -1 or another indicative value to signify that the attribute was not found
							End Try
						Else
							Try
							End Try
							Try
							End Try
						End If
					End If
					' Add a selected solid body to the component without Wavelink
						Dim added1 As Boolean = createNewComponentBuilder1.ObjectForNewComponent.Add(bodyToAdd)
					End If
					nXObject1 = createNewComponentBuilder1.Commit()
					lw.WriteLine("   Component created as: " & simpleFileName)
						Dim newComponent As NXOpen.Assemblies.Component = CType(nXObject1, NXOpen.Assemblies.Component)
						Dim newComponentPart As NXOpen.Part = CType(newComponent.Prototype, NXOpen.Part)
						' Switch to the new component part to work within its context
						Dim partLoadStatus As NXOpen.PartLoadStatus = Nothing
						theSession.Parts.SetWorkComponent(newComponent, NXOpen.PartCollection.RefsetOption.Current, NXOpen.PartCollection.WorkComponentOption.Visible, partLoadStatus)
						If partLoadStatus IsNot Nothing Then partLoadStatus.Dispose()
						' Setting up ScCollector and SelectionIntentRule for the body
						Dim scCollector As NXOpen.ScCollector = extractFaceBuilder.ExtractBodyCollector
						Dim selectionIntentRuleOptions As NXOpen.SelectionIntentRuleOptions = newComponentPart.ScRuleFactory.CreateRuleOptions()
						selectionIntentRuleOptions.SetSelectedFromInactive(False)
						Dim bodies() As Body = {bodyToAdd}
						Dim bodyDumbRule As NXOpen.BodyDumbRule = newComponentPart.ScRuleFactory.CreateRuleBodyDumb(bodies, True, selectionIntentRuleOptions)
						selectionIntentRuleOptions.Dispose()
						Dim rules() As NXOpen.SelectionIntentRule = {bodyDumbRule}
						scCollector.ReplaceRules(rules, False)
					End If
					End If
					theSession.CleanUpFacetedFacesAndEdges()
					' Add the new ID to the set to track it within the session
					usedIds.Add(llnextAvailableId)
					' Find the next available ID based on the fillTheGap setting
					If fillTheGap Then
						End While
					Else
					End If
				Catch ex As NXOpen.NXException When ex.Message.Contains("File already exists")
					lw.WriteLine(" ")
					lw.WriteLine("We attempted to fill the gap during component creation, but")
					lw.WriteLine("encountered an error because one or more removed parts are still")
					lw.WriteLine("in memory. Please close them in the NX session as well.")
					lw.WriteLine("Go to File > Close > Selected Parts.")
					lw.WriteLine("By Blackbeard's ghost, we're in uncharted waters... a complication has arisen: " & ex.Message)
				Finally
				End Try
			End If
		Next
		lw.WriteLine(" ")
		Dim endQuotes As New List(Of String) From {
			"Our expedition into the dusk reaches its twilight. Now, who recalls the spot of our anchorage?",
			"Our odyssey across the realms of power concludes.",
			"Our dance with destiny ends in silence.",
			"Our voyage through the storm finds its harbor in the void.",
			"Our voyage has sailed into the sunset. Now, who remembers where we parked?",
			"We've run out of road. Next stop: uncharted couch territories.",
			"That's a wrap on our adventure. Please exit through the gift shop.",
			"The end of our quest is here. Time to hang up our capes.",
			"We've navigated the void and returned. Yet, the darkness lingers, an eternal companion.",
			"Our expedition's final log. Beam us up, there's no intelligent life down here!",
			"Our shared path diverges here. May your socks always match in future adventures.",
			"The torch of our adventure dims, its light flickering one final moment."
		Dim rnd As New Random()
		Dim index As Integer = rnd.Next(endQuotes.Count)
		Dim selectedQuote As String = endQuotes(index)
		lw.WriteLine(selectedQuote)
		lw.WriteLine(" ")
		'lw.WriteLine("----------")
	End Sub
	Function IsComponentCreated(ByVal body As Body) As Boolean
		Try
			Dim attrValue As String = ""
			' Determine the target body based on whether it's an occurrence
			Dim targetBody As Body = If(body.IsOccurrence, body.Prototype, body)
			' Check if the attribute exists and retrieve its value
			If targetBody.HasUserAttribute("Component_created", NXObject.AttributeType.String, -1) Then
				attrValue = targetBody.GetStringAttribute("Component_created")
			End If
			' If the attribute exists but is empty, interpret it as "no" (False)
			If String.IsNullOrEmpty(attrValue) Then
				Return False
			End If
			' If the attribute value is a valid boolean string, return its boolean equivalent
			If attrValue.Equals("True", StringComparison.OrdinalIgnoreCase) OrElse
			   attrValue.Equals("False", StringComparison.OrdinalIgnoreCase) Then
				Return Boolean.Parse(attrValue)
			Else
				' If the attribute value is not a recognized boolean string, log a message and interpret as False
				lw.WriteLine("Arr, this 'Component_created' be flying a foreign flag: '" & attrValue & "' for " & If(body.IsOccurrence, "instance: ", "body: ") & targetBody.JournalIdentifier)
				Return False
			End If
			lw.WriteLine("Shiver me timbers, we've sailed into a storm... a mistake has been spotted: " & ex.Message)
		End Try
		' Return false if attribute not found, not valid, or any exception occurs
		Return False
	End Function
	Sub SetComponentCreated(ByVal body As Body, ByVal created As Boolean)
		Try
			Dim targetBody As Body = body
			' If the body is an occurrence, use the prototype body for setting attributes
			If body.IsOccurrence Then
				targetBody = body.Prototype
			End If
			' Set the user attribute on the target body
			targetBody.SetUserAttribute("Component_created", -1, created.ToString(), Update.Option.Now)
			' Log a success message indicating the attribute was set
			'lw.WriteLine("Attribute 'Component_created' set to " & created.ToString() & " for " & If(body.IsOccurrence, "instance: ", "body: ") & targetBody.JournalIdentifier)
			lw.WriteLine("Hitch in casting the line 'Component_created' on " & If(body.IsOccurrence, "instance: ", "body: ") & body.JournalIdentifier & " - " & ex.Message)
		End Try
	End Sub
	Function SelectObjects(prompt As String, ByRef dispObj As List(Of DisplayableObject)) As Boolean
		Dim selObj As NXObject()
		Dim title As String = "Select solid bodies"
		Dim includeFeatures As Boolean = False
		Dim keepHighlighted As Boolean = False
		Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
		Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
		Dim selectionMask_array(0) As Selection.MaskTriple
		With selectionMask_array(0)
			.Type = UFConstants.UF_solid_type
			.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
		End With
		Dim resp As Selection.Response = theUI.SelectionManager.SelectObjects(prompt,
		title, scope, selAction,
		includeFeatures, keepHighlighted, selectionMask_array,
		selObj)
		If resp = Selection.Response.ObjectSelected OrElse
		   resp = Selection.Response.ObjectSelectedByName OrElse
		   resp = Selection.Response.Ok Then
			If selObj IsNot Nothing AndAlso selObj.Length > 0 Then
				For Each item As NXObject In selObj
					If String.IsNullOrEmpty(item.Name) Then
						item.SetName(defaultsolidbodyname)
					End If
					dispObj.Add(CType(item, DisplayableObject))
				Next
				' Update EW_Body_Weight if EasyWeightsortinglogic is true
					For Each body As DisplayableObject In dispObj
						If TypeOf body Is Body Then
							UpdateBodyWeight(CType(body, Body))
						End If
					Next
					lw.WriteLine("")
					lw.WriteLine(" - Successfully updated the Weight information.")
					lw.WriteLine("")
				End If
				' SmartSort objects
						Try
							dispObj.Sort(Function(a, b)
											 Dim aMat As String = Nothing
											 Dim bMat As String = Nothing
											 Dim aWeight As Double = 0
											 Dim bWeight As Double = 0
											 Dim primaryResult As Integer = 0
											 Try
												 aMat = a.GetStringAttribute("EW_Material")
												 aMat = "zzzzz"
											 End Try
											 Try
												 bMat = b.GetStringAttribute("EW_Material")
												 bMat = "zzzzz"
											 End Try
											 Try
												 aWeight = a.GetRealAttribute("EW_Body_Weight")
												 aWeight = 0
											 End Try
											 Try
												 bWeight = b.GetRealAttribute("EW_Body_Weight")
												 bWeight = 0
											 End Try
											 Dim aNum As Double? = GetMaterialThickness(aMat)
											 Dim bNum As Double? = GetMaterialThickness(bMat)
											 ' Handling primary sort based on EW_Material attribute
											 If aNum.HasValue And bNum.HasValue Then
												 primaryResult = bNum.Value.CompareTo(aNum.Value) ' Sort in descending order
											 ElseIf aNum.HasValue Then
												 primaryResult = -1
											 ElseIf bNum.HasValue Then
												 primaryResult = 1
											 Else
												 primaryResult = String.Compare(aMat, bMat) ' Sort alphabetically in that case
											 End If
											 ' Handling secondary sort based on EW_Body_Weight attribute
											 If primaryResult = 0 Then
												 Return bWeight.CompareTo(aWeight) ' Sort in descending order based on weight
											 Else
												 Return primaryResult ' Otherwise, return the result of the primary comparison
											 End If
										 End Function)
							lw.WriteLine(" ")
							lw.WriteLine("Hoist the colors, we're navigating choppy seas... a fault has been discovered: " & ex.Message)
						End Try
					Else
						Try
											 Dim aMat As String = If(GetMaterialName(a) = "Not specified", "zzzzz", GetMaterialName(a))
											 Dim bMat As String = If(GetMaterialName(b) = "Not specified", "zzzzz", GetMaterialName(b))
											 Dim aNumVal As Double? = GetMaterialThickness(aMat)
											 Dim bNumVal As Double? = GetMaterialThickness(bMat)
											 ' Compare numerical values if both are present
											 If aNumVal.HasValue AndAlso bNumVal.HasValue Then
												 Dim numCompare As Integer = bNumVal.Value.CompareTo(aNumVal.Value)
												 If numCompare <> 0 Then Return numCompare
											 ElseIf aNumVal.HasValue Then
												 Return -1
											 ElseIf bNumVal.HasValue Then
												 Return 1
											 End If
											 ' If numerical values are equal or not present, compare the rest of the material name
											 Dim restCompare As Integer = String.Compare(aMat, bMat)
											 If restCompare <> 0 Then Return restCompare
											 ' If materials are identical, compare weights
											 Dim aWeight As Double = GetBodyWeight(a)
											 Dim bWeight As Double = GetBodyWeight(b)
											 Return bWeight.CompareTo(aWeight) ' Sort by weight in descending order
										 End Function)
							lw.WriteLine(" ")
							lw.WriteLine("Ahoy, deckhands, a squall's upon us... an anomaly has presented itself: " & ex.Message)
						End Try
					End If
					lw.WriteLine(" - Selected bodies captured and the Selection order: Sorted.")
				Else
					lw.WriteLine(" - Selected bodies captured and the Selection order: Preserved.")
				End If
				Return True ' Successfully selected and sorted objects
			Else
				' Handle the case where no objects are selected
				lw.WriteLine("The chronicle paused, as no items were marked for the journey.")
				Return False
			End If
		Else
			lw.WriteLine(" ")
			lw.WriteLine("Arr, what's this? A baffling response during the selection of the bounty: " & resp.ToString())
			Return False
		End If
	End Function
	Sub UpdateBodyWeight(ByVal body As Body)
		Dim myMeasure As MeasureManager = workPart.MeasureManager
		Dim massUnits(1) As Unit
		massUnits(0) = workPart.UnitCollection.GetBase("Volume")
		Dim mb As MeasureBodies = myMeasure.NewMassProperties(massUnits, 0.99, New Body() {body})
		' Update the InformationUnit for MeasureBodies based on unit system
		Dim informationUnit As MeasureBodies.AnalysisUnit
		If unitString = "in" Then
			mb.informationUnit = MeasureBodies.AnalysisUnit.PoundInch
		Else
			mb.informationUnit = MeasureBodies.AnalysisUnit.KilogramMilliMeter
		End If
		' Extract volume
		Dim bodyVolume As Double = mb.Volume
		mb.Dispose()
		' Extract density from the EW_Material_Density attribute; default to 1 if not found
		Dim density As Double = 1.0
		Try
			density = Convert.ToDouble(body.GetStringAttribute("EW_Material_Density"))
			' If the attribute is not found or cannot be converted, use the default density of 1
			'lw.WriteLine("Density attribute not found or invalid for body: " & body.JournalIdentifier & ". Using default density of 1.")
		End Try
			' Calculate weight assuming density is in Pound/Cubic Foot, converting to lbm
			Dim bodyWeight As Double = bodyVolume / 1728 * density
			Try
				body.SetUserAttribute("EW_Body_Weight", -1, bodyWeight, Update.Option.Now)
				'lw.WriteLine("Updated EW_Body_Weight for: " & body.JournalIdentifier & " to " & bodyWeight.ToString("F3") & " Lbm")
				'lw.WriteLine("Failed to update EW_Body_Weight for: " & body.JournalIdentifier & ". Error: " & ex.Message)
			End Try
		Else
			' Calculate weight assuming density is in Kg/Cubic Meter, converting to kg
			Dim bodyWeight As Double = bodyVolume / 1000000000.0 * density
			Try
				'lw.WriteLine("Updated EW_Body_Weight for body: " & body.JournalIdentifier & " to " & bodyWeight.ToString("F3") & " Kg")
				'lw.WriteLine("Failed to update EW_Body_Weight for body: " & body.JournalIdentifier & ". Error: " & ex.Message)
			End Try
		End If
	End Sub
	Function GetMaterialName(body As Body) As String
		' Retrieve the material name for the body
		Dim matName As String = ""
		Try
			matName = body.GetStringAttribute("Material")
			Return If(matName Is Nothing, matName, "Not specified")
		End Try
		Return matName
	End Function
	Function GetMaterialThickness(materialName As String) As Double?
		' Try to extract numerical value
		Dim pattern As String = "(\d+/\d+)|(\d+(\.\d+)?)"
		Dim matches As MatchCollection
		Dim thickness As Double? = Nothing
		Dim numericPart As String
		If materialName.Contains(ssunitmm) Then
			numericPart = materialName.Substring(0, materialName.IndexOf(ssunitmm)).Trim()
			matches = Regex.Matches(numericPart, pattern)
			'lw.WriteLine("Material name trimed (" & ssunitmm & ") : " & numericPart.ToString())
		ElseIf materialName.Contains(ssunitin) Then
			numericPart = materialName.Substring(0, materialName.IndexOf(ssunitin)).Trim()
			'lw.WriteLine("Material name trimed (" & ssunitin & ") : " & numericPart.ToString())
		Else
			matches = Regex.Matches(materialName, pattern)
		End If
		For Each match As Match In matches
			If match.Success Then
				Dim value As Double
				If match.Value.Contains("/") Then
					Dim parts As String() = match.Value.Split("/")
					If parts.Length = 2 Then
						Dim numerator As Double
						Dim denominator As Double
						If Double.TryParse(pa
Tutorial for the Component Creator Journal
To name the solid bodies, follow these steps:
[ul]
[li]Navigate to: Part Navigator / Reference Sets / Model / Solid bodies[/li]
[li]You can rename the solid bodies here by slowly double-clicking on them.[/li]
[/ul]
[ul]
[li]To modify the default solid body name, locate this line in the journal:[/li]
[/ul]
Code:
If you don't see the Reference Sets folder, go to:
[ul]
[li]Customer Defaults / Gateway / Part Navigator / Display Reference Sets Folder[/li]
[/ul]
If you can't enable the Reference Sets folder:
[ul]
[li]Right-click in an empty area within the Part Navigator[/li]
[li]Deselect 'Timestamp Order' from the menu[/li]
[li]This action will make the Reference Sets folder visible, allowing you to name the solid bodies.[/li]
[li]Select the solid bodies you want to rename[/li]
[li]Right-click on one of the selected bodies[/li]
[li]Navigate to Properties / General / Name[/li]
[li]Enter your desired name[/li]
[li]If you see an ‘Apply to Work Part’ option under the name, it means you're in a different environment from the original. Make sure to select this option to apply the changes[/li]
[li]After completing the naming process, return to the Part Navigator, right-click in an empty area once more, and re-select ‘Timestamp Order’ to revert the settings.[/li]
[/ul]
If you want to handle them in the graphics window:
[ul]
[li]Set your Selection / Type filter (selection scope) to Solid Body[/li]
[li]Select the solid body / bodies you want to rename[/li]
[/ul]
And that's all. I hope it helps.
I just ran thru this tutorial, on a test assembly, I'd already created with your journals, and when I added names to the bodies, IT EVEN updates, RIGHT THRU the assembly, this is GREAT stuff..
This journal is great, but to suit my needs, i'd like to modify it a bit.
I changed the line you suggested (in the Component Creator) and I can now select any bodies in the assembly levels below the top level work part, and it adds the new parts at the bottom
, then i can drag them under the correct part ALL the while keeping the links intact (brilliant)
..I wonder... is it possible to modify it, to work if I'm work part at a lower level, because up to now it'll error if you're not right at the top of the assembly.
Other nice to have's would be...
1. can I set the creation location to "same as work part" by default, and let the user input, specify a new location if needed?
2. can I set the new component name to be "the work part name" (already in the input window) ready to be edited by the user input?
My edited code is below, i removed the word PANEL from the component names, and used numbering 001, 002, 003 etc.
' Written in VB.Net
' V103 - Teamcenter Integration & Local Support, Smart Sorting with EasyWeight or NX's built-in material attributes, Metric (Millimeters) and Imperial (Inches) unit support in Material name, WaveLink Option, Flag Created Components Option, Control Numbering Gaps Option and added Configuration Settings
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Dim EasyWeightsortinglogic As Boolean = True
' If you wan't to override this later, simply delete the value of this attribute in Solid body / Properties. - True or False
' Only for EasyWeight users - The EW_Material journal automatically adds an empty 'Component created' attribute to solid bodies, addressing a discovered issue in version 1.01.
' You can go around this by assigning the attribute to all your solids at first. Select all Solid Body / Properties / New Attribute / Title: Component created, Data Type: String. A more efficient way would be to change your model template to have this by default.
' TC Settings
' Local Settings
Dim llTemplateFileName As String = "model-template.prt"
' WaveLink Settings
lw.Open()
theUI = UI.GetUI()
lw.WriteLine("Captain Hook's Component Creator Version: 1.09 NXJ ")
lw.WriteLine(" ")
lw.WriteLine(" ")
Else
lw.WriteLine(" ")
Return
End Select
End If
Else
End If
Else
End If
Else
lw.WriteLine(" ")
Return
End Select
End If
End If
Try
lw.WriteLine(" ")
Return
lw.WriteLine(" ")
Return
lw.WriteLine(" ")
Return
End Try
End If
End If
unitString = "in"
Else
unitString = "mm"
End If
lw.WriteLine(" - Save to : " & lldirectoryPath)
End If
Dim assemblyid As String = InputBox("Please enter your required ID Name - etc. MyProject-01", "Component Creator")
Else
lw.WriteLine(" ")
Exit Sub
End If
End If
lw.WriteLine(" ")
Dim nextAvailableId As Integer = 001
usedIds.Add(idPart)
End If
End If
Next
usedIds.Add(idPart)
End If
End If
Next
End If
If fillTheGap Then
While usedIds.Contains(nextAvailableId)
End While
Else
End If
End If
End If
Dim AssemblyidString As String = assemblyid & "-001"
lw.WriteLine(" ")
Continue For
End If
End If
Continue For
End If
Try
End If
lw.WriteLine("")
Try
End Try
Try
bodyWeight = -1
End Try
Else
Try
End Try
Try
bodyWeight = -1
End Try
End If
End If
' Configure the ExtractFaceBuilder
End If
End If
If isFirstSave Then
Try
End Try
End If
'lw.WriteLine(" ")
isFirstSave = False
Else
End If
AssemblyidString = assemblyid & "-00*"
End If
lw.WriteLine(" ")
Try
End Try
Try
bodyWeight = -1
End Try
Else
Try
End Try
Try
bodyWeight = -1
End Try
End If
End If
End If
End If
lw.WriteLine(" ")
Finally
End If
End If
End Try
Else
Try
Dim newFileName As String = lldirectoryPath & baseAssemblyId & nextAvailableId.ToString("D3") & "-" & selectedObjectName & ".prt"
Dim simpleFileName As String = baseAssemblyId & nextAvailableId.ToString("D3") & "-" & selectedObjectName & ".prt"
lw.WriteLine(" ")
Try
End Try
Try
End Try
Else
Try
End Try
Try
End Try
End If
End If
End If
End If
End If
usedIds.Add(nextAvailableId)
If fillTheGap Then
End While
Else
End If
lw.WriteLine(" ")
Finally
End Try
End If
Next
lw.WriteLine(" ")
lw.WriteLine(" ")
End Sub
Try
End If
Return False
End If
Else
Return False
End If
End Try
Return False
End Function
Try
End If
End Try
End Sub
' Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
' changed this line
Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
End With
selObj)
End If
Next
End If
Next
lw.WriteLine("")
lw.WriteLine("")
End If
' SmartSort objects
Try
Try
aMat = "zzzzz"
End Try
Try
bMat = "zzzzz"
End Try
Try
aWeight = 0
End Try
Try
bWeight = 0
End Try
primaryResult = -1
primaryResult = 1
Else
End If
Else
End If
End Function)
lw.WriteLine(" ")
End Try
Else
Try
Return -1
Return 1
End If
End Function)
lw.WriteLine(" ")
End Try
End If
Else
End If
Else
Return False
End If
Else
lw.WriteLine(" ")
Return False
End If
End Function
Else
End If
' Extract volume
mb.Dispose()
Try
End Try
Try
End Try
Else
Try
End Try
End If
End Sub
Try
End Try
Return matName
End Function
Else
End If
Dim value As Double
If Double.TryParse(parts(0), numerator) AndAlso Double.TryParse(parts(1), denominator) AndAlso denominator <> 0 Then
thickness = (numerator / denominator)
thickness *= 25.4
End If
'lw.WriteLine("Calculated Thickness: " & thickness.ToString() & " - from (Fraction)")
Return thickness
End If
Return thickness
End If
ElseIf Double.TryParse(match.Value, value) Then
thickness = value
thickness *= 25.4
End If
'lw.WriteLine("Calculated Thickness: " & thickness.ToString() & " - from whole or decimal number")
Return thickness
End If
End If
Next
Return Nothing
End Function
Function GetBodyWeight(body As Body) As Double
Dim weight As Double = 0.0
Dim myMeasure As MeasureManager = theSession.Parts.Work.MeasureManager
Dim theBodies(0) As Body
theBodies(0) = body
Dim massUnits(4) As NXOpen.Unit
massUnits(2) = theSession.Parts.Work.UnitCollection.GetBase("Mass")
Try
Dim mb As MeasureBodies = myMeasure.NewMassProperties(massUnits, 0.99, theBodies)
weight = mb.Mass
mb.Dispose()
lw.WriteLine(" ")
lw.WriteLine("Arr, we've hit a snag in weighing our cargo: " & ex.Message)
End Try
Return weight
End Function
End Module
Hi Tamas,
I've been using my edited version of your component creator, but I've noticed that it won't add more components, I must've broken it...
can you help me to remove the "PANEL" on the end of the part numbering, so I don't break the rest of the code.
I love this journal, i'm just not good enough to be able to sort it out. I'd really appreciate your help..
Hey moog3,
It's been a while...I haven't checked your modifications, and I hoped you achieved what you wanted to...but it's soo easy to brake the code with only one misplaced character, so
First thing first, I've noticed you are using an older version (V109), so please update it to the latest - V111. In this version I added a few more customization options for you all to be easier to tame this journal. It's in my very first comment in this page - BUT - eng-tips must have changed the website and it doesn't use my comment formats any more, also the code got trimmed down (probalby there's a limit now)...if you can't see the end of the code (End Module) it is useless. Please go to NXJournaling.com or GitHub and download from there (Links are still working in the first comment).
Now, the changes you have to make with all your wishes combined - (Note: This will affect only the local (non-Teamcenter) environment), so:
Line 80:
1. Since you are moving from one journal to another, copy paste your main settings
Line 126:
' Local Settings
2. To select solid bodies from anywhere in the main assembly
Our conversation about this (comments #15 and #16 ):
Line 1091:
To:
3. Change the the counter from 101 to 001
Line 131:
To:
Dim llnextAvailableId As Integer = 001
4. Remove solid body name from the created part's name
Line 72:
To:
Dim defaultsolidbodyname As String = "MYSTERY_MESH"
Line 863:
To:
Dim newFileName As String = lldirectoryPath & baseAssemblyId & llnextAvailableId.ToString("D3") & ".prt"
Dim simpleFileName As String = baseAssemblyId & llnextAvailableId.ToString("D3") & ".prt"
Tested through with the fillthegap funtion and it works well to me.
Give it a go and tell us the outcome.
Hi Tamas,
Thanks for your help, this is "bloody brilliant"....
I had to edit the code as the second input box had been disabled. I edited from line 244 to look like this, to get that back again..
'If assemblyidQST Then
'assemblyid = InputBox("Please enter your required ID Name - etc. MyProject-01", "Component Creator")
Else
lw.WriteLine(" ")
Exit Sub
End If
End If
'Else
'assemblyid = defaultassemblyid
'End If
could you please show me how to "auto fill" the dialog boxes with the path of the work part, and the name of the work part
this would make it quicker for us. The path for us is always, the same as the work part, but an auto fill is fine... (probably better, as it adds flexibility)
Thanks again...
Yes, thank you for pointing this out! During testing, I forgot to change the ID name question, so it stayed off. Also, I buried the setting in the Teamcenter section 🤦‍♂️ (I was too focused on making this part fully custom). Apologies for that! If anyone reading this, you don’t need to go deep into the journal—everything has an option in the Configuration Settings.
Moog3, please copy-paste back your modifications, and only change this line from 'False' to 'True' (if it is 'False', it uses the defaultassemblyid):
(I also updated it on NXJournaling; it was okay on GitHub)
Line 124:
Unfortunately, I can’t experiment with this journal much—only if an error occurs. However, I use these every day, so if something would fail after a future NX update, don’t worry; I’ll be on it to fix it. I’m very busy at work, and when I have time, recently I’m learning Spanish :)
So, I’ll leave this to you, but I think it’s completely achievable. If you don’t mind, here are some tips:
Since you’re only using it locally, I left two versions on GitHub: V109 (Only Local) and V111 (Local and Teamcenter). Switch to the Only Local version. Why? It’s much shorter, and all the functions are the same!
Use Notepad++. It highlights code in different colors, and double-clicking a variable will highlight all related instances, making it easy to trace.
Feed the whole code or the main part into your favorite AI helper. Count with many errors and trials. Copy-paste them back.
Your prompt could be (I asked Claude to make this good for you)
I need help modifying a Siemens NX Visual Basic journal that handles component creation behavior. Currently, our code has several core functions that create a component, set them as workpart, create the required wavelink, return to the main assembly, and then move on to process the next selected solid body.
We're facing an issue with the current code structure. While it successfully initializes components in the main assembly, this approach no longer suits our needs because we're now working in a larger environment where components need to be created in their specific subassemblies, and the solid bodies we're working with exist in different subassemblies.
To address this, we need to modify how the main assembly gets initialized and ensure that each component is created in the same subassembly where its corresponding solid body exists. The current component naming and numbering scheme should remain unchanged, and we don't need to implement error handling.
Could you help me modify only the relevant sections of code to achieve this? Specifically, I'd like you to:
1. Identify which sections of code handle assembly initialization
2. Suggest specific modifications needed for these sections
I hope it helps!
Buena suerte, amigo / amiga
I also want to grab the moment to express my gratitude for Siemens NX. This software with all the customizations available through NX Open is incredible. I hope one day, these features will become native parts of NX, but until then, we’re making great use of journals. A huge thank you to the developers!
I completely understand, thanks for giving ALL of us your time, & great advice. (I'm using the native one now)
I did find a minor annoyance..., when you hover over a part name in an assembly, it says MYSTERY_MESH instead of the part name....., i'll keep chipping away..
I can't PM you on here, so I found you on linkedin, I wanted to pose a question... you may be interested in, I requested to connect... (Paul)
You can now, with the updated forum. Click on someone's user name and then choose "start conversation"; this will send them a direct message.
Cowski, I had no idea you read all these… thank you for all your insights here and on NXJournaling. Your wisdom has always pointed me to the right direction, and I’m truly grateful. Thanks so much man!
Nice to meet you, Paul! Your request accepted!
Yes, I have forgotten! Do the following as an addition to the previous changes - locate these lines in the journal and delete them:
In the Main Sub, after the setcomponentflag check (V109 Native - Line 276, V111 TC - Line 353):
Continue For
End If
And in the SelectObjects Function (V109 Native - Line 533, V111 TC - Line 1113):
End If
Greetings to the other side of the World!
(my profile is 5 years out of date...), yea, good to chat.. done those it just says that its in the assembly now, but it's REALLY not a biggie..:)
