JQCF1
- Aug 10, 2005
- 50
Hi All,
This is not a repair but an access hole to be put in belly shell of a vintage Bell 206 helo. Say 4" x 6" for discussion purposes with radiused corners in flat honey comb floor and say 1" thick with .025 al facings on H'comb panel.
Current thoughts are to reinforce around opening with 1.75 wide,.040 2024-T3 top and bottom, apply doubler with CherryLocks and fill voids with Hysol/Loctite EA 934 epoxy. We will also use Delron plug/sleeve inserts to get 10-32 thds around hole for closure plate. Any thoughts on doubler thickness and analysis methods if required? Gut feel says this scheme is OK but the Feds may require more detail. 43.13 no help since this is not a repair of damaged h'comb.
Thanks for your comments. John Cragin
