ACE58
- Feb 13, 2006
- 28
I am currently designing a steel frame medical office building & the architect has requested I use unshored composite steel-concrete floor beams to minimize depths & cost. The only reference I have for this type construction is the 9th Edition of the ASD Manual. I have followed the procedure detailed there for std. simple span beams & have designed a number of them already. My question pertains to the main beams which support these simple span beams on the column lines. If one of these main beams (28' long)supports simple span beams @ 9'-4"c/c from each side (bay sizes 21' & 9') what value is used for the effective width of concrete slab, "b" (step "C" in design example 15) for these main beams? Using either L/4 or (21+9)/2 both result in what seems to be an excessive number of shear studs compared to a past job I am referencing (designed by another firm). Any advice would be appreciated.
