Composition of Sea Water
arsmith
Mining
Apr 18, 2001
9
Can any one out there give me the Chemical Composition of Sea Water (aproximate) ,I mean the salts disolved in it in ppm
Usually the main concern is with Cl, which is ~20,000+ PPM, depending on the ocean. There's also a few thousand PPM sulfate, IIRC.
My CRC Handbook of Chemistry and Physics has 2 tables for the composition of seawater:
a) By elements (81 are listed),
2) By major ions (13).
This is one of the best on-line listings by ionic makeup, listed in order of decreasing composition:
This gives the total composition of seawater, with 1st the few major components, then for all the elements (in order of atomic weight) :
As an example, the Composition OF Arabian Gulf seawater:
Cations:
sodium 13440 ppm
potasium 485 ppm
calcium 520 ppm
copper 0.004 ppm
iron 0.008 ppm
strantium 1 ppm
boron 3 ppm
Anions:
chloride 24050 ppm
sulfate 3380 ppm
biocarbonate 165 ppm
carbonate 88 ppm
bromide 1 ppm
TDS 42528 PPM
pH 82 ppm
Note the concentration varies from season to season and from site to site.
