Billykeys
Automotive
- Sep 8, 2021
- 2
I'm trying to agree on a datum system between my engineers and a supplier...
The part has two primary functional planes, unfortunately not perpendicular. Normally one plane would be primary, slide against the second.
What is the proper way to establish a coordinate system from these 2 planes? (The tertiary will be a hole drilled into the A plane, that's more straightforward)
My thought is to establish a plane with the B feature (This is as-cast, I think I would call it Y instead, to align with X-Y-Z as-cast norms), translate it down to A, the line generated from the A-B intersection actually becomes the B datum (rotate the "Y" plane 10° where it intersects A, call that B.
Any thoughts? or what is a good way to use two non-perpendicular planes as datums? (My engineer just wanted to leave it with the A and B as shown on the attachment - It is not possible to have two non-perpendicular planes as the datum system subsequently referenced in feature control frame GD&T, is it?) I saw a reference to using two planes as a "compound datum", but I think that's only when they a parallel, and a 'mid-point' plane becomes a "A-B" datum, but two oblique planes?
