jasoncwells
Aerospace
- Jun 23, 2014
- 52
A long time ago, I recall that there is a concern with compression ignition of oil or other flammables inside a pneumatic system if the rate of pressurization was too high. The place that I used to work had really high air pressures. I'm not a pneumatics guy as my day job. My google-fu gives me lots of links about diesel engines.
The air pressure in the proposed system will be 500 psig. Perhaps ignition is not a concern at lower pressures.
Can you point me to a good reference for this?
