EspElement
If I am making a bar link system and I use bronze bushings on the pivot points. If I put force on the shaft momentarily against the bushing (impact load - while link is stationary), how do I calculate the allowable pressure on the bushing area? I have in the past taken half the circumference of the shaft by the width and that's how I determined the area of compression. But I don't think this is 100% accurate. Would the points close to the quadrant take more load then the points 45° to that?
I have searched and looked thru some books and I suppose I'm not researching the proper name of this type of load.
