Compression Spring Shear Spring Rate
xr4titis
21
Hola Forum,
Does anyone have a formula to derive the shear spring rate of a compression spring? In other words, the spring rate in the plane perpendicular to the axis of the spring.
I've seen this provided from a German spring manufacturer (that I can no longer get a hold of) as a function of in-axis deflection.
It doesn't need to be exact, just trying to determine feasability. Rough dimensions: O.D. = 8", Wire Dia. = 1" Free Length = 9", Travel = 3", Mat'l = Alloy Steel
Gracias,
Andrew
Hi xr4titis
Kx = 10^6*d^4/(Cl*n*D*(0.204Hs^2 + 0.265*D^2)
Kx= lateral stiffness of spring
Cl= factor depending on vertical deflection due to load divided by the spring free length and the free length divided by the mean diameter of spring
n= number of active coils
Hs= compressed length of spring
D= mean dia of spring
d= wire dia of spring
Can you give me the rate of your spring and the number of active turns and I'll get the Cl factor for you.
regards
desertfox
thanks desertfox!
I'm still in the very early stages of design, but the spring rate will be around 5000 lb/in. Do you know the approx range of the Cl factor?
Andrew
Hi xr4titis!
spring rate for compression spring derived formula is as
follows
Kx=G*d^4/8D^3n
Design follows iterative process intitally assuming wire dia & Spring index w.r.to space requirement & load requirement.
Hope it will help you
desertfox..Do u have derivation for the formula
John
Hello thought2007
The op hasn't been in for over a week I assume he got the last part of the answer somewhere else.
In addition I think you misinterpreted the post he wanted the spring rate at 90 degrees to the normal axis of spring.
desertfox
Hey Guys,
Sorry I've been away from work for a while, but I would still very much appreciate the Cl factor for the lateral spring rate. I haven't correctly sized the springs yet as I am new to suspension design therefore I cannot provide exact parameters. However, the application is rail so the springs will be pretty beefy. Inner and Outer spring combined stiffness of 10,000 to 15,000 lb/in. Can you please provide an approximate range for Cl? Possibly as a function of Vertical deflection?
Spring Design and Application editrd by Nicholas P. Chironis 1961, printed by McGraw Hill. Pages 61-62.
Mechanical springs, by A. M. Wahl 1963 pages 70-72 Chap. 5-13 Lateral loading of compression springs.
Mechanical Springs, by A. M. Wahl 1963 pages 282-284 Chap. 24-4 Combined axial and lateral loading.
