I have a question, just to check that my understanding of inlet pressure control is correct. I have a schematic that shows a PT on the inlet of a compressor. This signal is then fed back to the turbine driving the compressor ( to either speed up or slow down)
My question is: depending on the inlet pressure range is there then a set range of what the outlet pressure can be?
