BigInch
Petroleum
- Jun 21, 2006
- 15,161
I've got a problem with a small concrete beam, roughly 400mm x 200 mm wide, forming part of the roof support of an underground pump house. The top of the beam is flush with grade elevation. The span is not more than 2.5 meters, with very little real load from the adjacent 1 m wide slab that can only accept foot traffic. There has been considerable water penetration from the adjacent earth and surface dripping and the bottom of the beam has deteriorated with the humidity to the point where the outer clear distance has spalled off and the bars have become exposed and rusted. It has two temporary supports holding the beam up now, but I think that those might not really be necessary; just a safety measaure. I'm not sure, so I will verify the full extent of damage. My question is, provided the exposed bars are still sound, is there a way to replace the concrete lost from the beam, perhaps using epoxy grout formed to replace the original concrete clear cover around the existing bars, or is there some other method I could be looking at? I would imagine that all depends on the present integrity of those rusted tension bars. If necessary, is it possible to replace the bars themselves and if so, how would one go about doing that?
Any advice on the matter is greatly appreciated.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO, BP
"Being [c
"Being [c
