joshmaughan
- Jan 23, 2009
- 15
I have been asked to look at some spalling that is occuring along the bottoms of some precast/prestressed concrete roof double tees in an industrail building. T
he span is very short (22') and the tees are 18" deep. The only load is dead load (self wt.) and a 40 psf snow load, so the loading is minimal for this span and type of construction. The building has been in place for roughly 40 years.
The spalling is occuring along the bottoms of the slab portions of the tees, and along the panel joints. None on the stems. Most of the spalls are about 2" X 2" and 1" deep or so. Some are larger, some are smaller. Most of the spalling appear to be recent, as chuncks of concrete are still on the floor in several places.
It is very stange. No loading changes, chemical exposure, or extreme temperature changes have occured as far as we can determine. The room that this is occuring is around 80 degrees F constantly, with a ceiling temperature around 100 degrees or so.
Has anyone seen anything like this? Any idea what could cause it at this point in time? Thanks! See attached pic.
