MegaStructures
- Sep 26, 2019
- 376
I have a unique reinforced concrete non-building structure that I will analyze using an FEA model. The structure is basically a rectangular tube with two side walls a slab roof and a floor. I have one design example to follow and the design uses what appears to be beam elements for reinforcing bar and solid quad4 elements for the concrete. I think this is very complicated and introduces a higher probability for user error and requires the use of a more powerful FEA program other than a SAP-2000 or Risa that is a little easier to use for us structural engineers.
My question to all of you is: Are you aware of the research behind SAP-2000 and Risa's method of plate modeling for reinforced concrete slab design and is there any research available that directly compares the accuracy of this method over the more detailed method of explicitly modelling each reinforcing bar?
