liam1369
- Nov 13, 2014
- 73
Good Afternoon All,
I am scheming a concrete frame for a education building over a basement. It is only 4 stories and will be 'braced' with concrete cores and walls, therefore, all the columns are to be considered as 'braced.
As part of the proposal, I am proposing to make the columns rectangular to better fit in wall lines and not stick out in large classrooms etc. However, does anyone have any experience with these rectangular columns. In particular the following:
- Dimensions: At present I am thinking of going for 250 wide by 500mm long columns, to help with fire and give an initial section size. What is a typical size for a 4-5 story building with column grids circa 6x7m with flat slab 250-275mm.
- Orientation: I am initially thinking to have the longer side (500mm) of the column to the external perimeter line, this will help with moment and anchorage? - I know it is about the weaker axis though, however, I don't think there will be too much issue.
- I have proposed a 100mm - 150mm perimeter edging / nib which helps out with infill walling or build up required. Potential air gap cavity before masonry support angle springing off of the edge.
I have attached a couple of JPEG images clarifying what I am proposing above.
Does anyone have any experience with concrete frames and design of columns / flat slabs in general? Is there a benefit to orientating the columns so the longer side aligns with the slab perimeter edge or is it better to rotate so the shorter axis aligns to the perimeter edge?
Looking for initial pros and cons or whether there is a better way of doing things. I do not have much experience with concrete frames.
Many thanks for any help or input into this, I will be interested to know your thoughts.
Kind regards,
Liam
Kind regards,
Liam
